MOTM
[ot] Tolex covering?
2001-10-17 by Mike Marsh
Does anybody have experience with or links to descriptions for
covering plywood with Tolex?
Thanks!
Mike
RE: [ot] Tolex covering?
2001-10-17 by John Speth
I used tolex to cover my MOTM cabinet. It's not the elegance of wood, of course, but the stuff works like a dream. By that, I mean that it's stable enough to be strong but stretches just enough to make it easy to apply. It's relatively expensive but worth the money, IMO.
I bought some from a guy in town who recovers Fender amps. He gave me all the tips for using it. Use 3M Spray 90 for adhesive and use a new exacto knife for the trimming after applying the tolex. I bought metal corner protectors so I wouldn't have to worry about my corners. You should go to local music stores, etc to look at the Fender method of covering. There seems to be a standard for overlapping (when to, when not to, and how much), and corner work that Fender has used over the years.
One last tip, I covered my cabinet in August (warm time). I bet the stuff doesn't work so well in January so apply it while in a warm room.
John Speth
mailto:johns@...
Re: [ot] Tolex covering?
Thanks, John!  All good info, and appreciated.  I have two plywood
cabinets that are painted black, but I want to cover them with
snakeskin (!) I have the corners and the feet, and just needed
reassurance that it wasn't a tricky job, because as you say, the
stuff's expensive.
Snakeskin MOTM...
Mike
wood, of
it's stable
apply.
me all
exacto
corner
should go to
There
how much),
the stuff
> John Speth
> mailto:johns@m...
