motm-480 cs-80 filter configuration?
2002-02-11 by Jeffrey Pontius
(1) Just taking my first look at the motm-480 panel, noticing the BP and LP outputs. Is the configuration of this filter as follows: audio enters the low pass filter first (so is available for output) and then the low pass filtered audio enters the high pass filter (so audio is now band pass filtered)? Hence, this is the reason that a high pass output is not available. If so, seems like a similar audio setup to the Korg MS20 filter section (though different filter designs, I assume). (2) Are there any "module connection additions" on the drawing board (or in someone's imagination) that make this feature worth the advertisement space? Thanks, Jeff
