MOTM
More MiniMoes!
More MiniMoes!
2002-02-20 by mate_stubb
All,
I have updated the MiniMoe page with two more designs, a 4U and a 5U
wide. Next up, an 8U. Things are starting to get interesting now.
Alas for me, it's starting to look like I'll need expander modules.
So the whole thing may end up modular like SuperMoe anyway, just on a
finer scale.
http://www.hotrodmotm.com/minimoe.htm
Moe
Re: [motm] More MiniMoes!
2002-02-20 by blip
i *really* like the 4U version. this module looks like a unique and
beautiful instrument for improvisation. i'd buy one of these even though
i've already got two seqeuncers (but i'm a sequencer slut, heh). i have
one question though... what do the yellow leds indicate? or are they not
leds? :)
> finer scale.
one thing that confuses me about these sequencers is the function of the
individual set and position outputs... are these gate and cv outs for each
individual step? personally, i don't have near enough stuff to utilize
such a feature. i think these outputs would make a great expander module
for those who do, though.
excellent work moe!
bleep.
out.
www.mp3.com/leichenfeld
www.mp3.com/captainhotrod
www.mp3.com/silenttristero
i have one question though... what do the yellow leds indicate? or
are they not leds? :)
They indicate the current stage. Look at any step sequencer and they
will have an LED indicator per stage, one of which is lit when a
stage is selected. Most sequencers have a single row of pots, but
when designing in a narrow MOTM format, the rows have to be broken in
half and run vertically instead of the more conventional horizontal
direction. So you need 4 LEDs to indicate the row, and 2 to indicate
the column. Once you get out to an 8U panel though, you can run the
rows the correct way.
the individual set and position outputs... are these gate and cv outs
for each individual step? personally, i don't have near enough stuff
to utilize such a feature. i think these outputs would make a great
expander module for those who do, though.
That's two questions <g>. A position output is just a gate associated
with a certain stage, which is at logic high whenever that stage is
selected. The Set jacks are inputs to each stage, not outputs. A
logic high pulse on a Set input sets that stage to be active
immediately. So by patching various POS outputs to SET inputs, you
can make the sequencer run between an arbitrary set of stages. The
position gate outputs can also be used to trigger envelope generators
or random other chains of events once a particular stage is reached.
Moe
2002-02-20 by thomas white
Great work Moe, can't wait to see the 8u version! Any of these with the
gate/trigger sequence generator design on your site and I'm good to go! The
5u is my preferrence so far and I'm sure the eight will take that spot with
more features. I for one am willing to spend my time with this project and
build a very functional unit. Obviously the more complicated the better for
me and my needs. The gate sequencer would be a valuable side-kick to this
and could we see it down the road after the initial sequencer hits possibly?
If not maybe we can DIY some of these up if we can find the 3 or 4 guys
needed for the panel. Sorry to press the issue I guess but this type of
module is neceassary for any sequencing I plan to do with drums (most
excited about the MOTM drums)
Thomas White
>From: "mate_stubb" <mate_stubb@...>
>To: motm@yahoogroups.com
>Subject: [motm] More MiniMoes!
>Date: Wed, 20 Feb 2002 15:30:56 -0000
>All,
>finer scale.
>Moe
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp.
2002-02-20 by blip
oh a matrix... i get it... that's what i thought they were for, but i
didn't realize they were a matrix.
whoa... the possibilities...! i still think that would be a better
expander (1U?) for a 4U MM than part of a larger module. or perhaps the
following breakdown makes more sense:
original 2U minimoe
2U Mode Switch expander (would contain the directon switch)
1U SET/POS expander
i think this setup would allow a lot of ppl to get up and running with
these things real quick... it would get *me* going at least. :)
bleep.
out.
2002-02-20 by George Kisslak
Moe,
Lookin good!  Could you please explain how the chain1 and chain2 selection
switch works?  I'm assuming somehow this is used to chain addl. modules for
more rows and/or columns, just not sure how it would work.
George
2002-02-20 by Josue Arias
Wow,
Great designs!
I noticed the range switches for 0 to +5V or -5 to +5V. I think would be more useful having -1 to +1 or 0 to +10V instead the 0-5V
What do you think?
Josue.
2002-02-21 by jwbarlow@aol.com
Hey Moe,
I'd originally thought you could get a pretty good (if basic) sequencer happening in a 3U or 4U MOTM format. Now that I look at what you've shown us, I think a good sequencer would have to be bigger -- and you might as well go to 8U.
I really like the 8U version that you've got up there now -- looks very EMu, partly due to the silver panel. I do have a few questions about it.
It looks like the horizontal distance between the knobs is less than the MOTM standard? If so, it might be worth considering a smaller knob size.
Does the mode switch allow one to do anything that they couldn't accomplish with patch cords?
Why a PIC? Why not just use CMOS stuff? Then you might have to move the four bit counter out to a separate module, but that might allow for some interesting possibilities for sequencer usage.
Great work so far!
JB
In a message dated 2/20/02 7:34:02 AM Pacific Standard Time, mate_stubb@... writes:
2002-02-21 by mate_stubb
about it.
Thanks! Actually, it's more of a ringer for the Moog 960, feature-
wise.
knob size.
Yes, they are 1.5" on center instead of 1.75". There is no need to go
to smaller knobs - I've tested it in an 8x4 pot matrix and you don't
feel the difference at all.
Not sure if you are talking about the CHAIN switch or the rotary
stage select mode switches.
If you mean the rotary switches, the answer is: not without adding a
LOT of jacks to the panel. I don't know how you would do random state
selection with patch cords, especially on a per-stage basis. Also,
the rotary switches are more conducive to switching on the fly,
allowing you to actually 'play' the sequencer in a live performance.
Last time I checked, people rated the ability to skip a stage very
highly.
If you mean the CHAIN switch, the same answer applies. If I want to
make two 8 stage sequencers seamlessly connect to appear to be a 16
stage sequencer, and support random bidirectional play and random
stage selection across multiple modules, there has to be a bus that
the modules use to communicate status and requests. That doesn't
really lend itself to connection via front panel patchcords.
The simpler modules could easily be done with discrete logic. I have
a SuperMoe address generator module designed this way. But once I add
the rotary switches for all those stage select modes, you have to
build decision-making into it. The PIC is the easiest way to go, and
actually ends up being cheaper than the many chips it would replace.
Not to mention being able to add features in software later.
Let me restate that none of these designs route the actual control
voltages from the pots through a PIC or ADC - the PIC just controls
analog multiplexers.
Moe
