Even more demos
2002-02-28 by Paul Schreiber
New demos on the '310 and '320 pages. Note that these demos aren't the only ones for these modules. I plan to add/swap/rotate them to keep things interesting. As a whole, these newer demos show off the modules better than the ones from 2yrs ago. Thanks again. Paul S. back to "work", grumble
2002-03-01 by Les Mizzell
Evening, Hopefully you won't hate this Paul, but.... On the MOTM 800 EG - assuming you're using banana plugs on all in/out jacks, what would the correct wiring to the plugs be for the unit to properly function... It's pretty straight forward until you get to the Trigger Mod, which is switched on the 1/4 jack. Since my keyboard has both trigger and gate, so is it even needed at this point? So, seems it would be: 1. J2 to Trigger in 2. J1 White to Gate in 3. J4 to minus out 4. J3 to plus out OK, what do I do with the Trigger Mod and the orange (switched) J1 wire? Thanks.... Les Mizzell - - - - - - - - - - - - - - - - Some days you're the dog; some days you're the hydrant. - - - - - - - - - - - - - - - -
Boy, just mention banana plugs and suddenly nobody will talk to you anymore! > OK, what do I do with the Trigger Mod and the orange (switched) J1 wire? > It's pretty straight forward until you get to the Trigger Mod, I'm thinking at this point of adding two switches to the panel, and then attaching the wires, through the switches and to the appropriate jack on the panel. Then I can just switch them on or off as needed, depending on what I'm using as a trigger at any point... Anybody got thoughts on this? Surely I'm not the only person in the world that's putting banana plugs on a MOTM. Or am I? Les Mizzell - - - - - - - - - - - - - - - - Some days you're the dog; some days you're the hydrant. - - - - - - - - - - - - - - - - > -----Original Message----- > From: Les Mizzell [mailto:lesmizz@...] > Sent: Thursday, February 28, 2002 9:49 PM > To: Paul Schreiber; MOTM listserv > Subject: [motm] 800 EG with banana plugs question > > > Evening, > > Hopefully you won't hate this Paul, but.... > > On the MOTM 800 EG - assuming you're using banana plugs on all > in/out jacks, > what would the correct wiring to the plugs be for the unit to properly > function... > which is
> switched on the 1/4 jack. Since my keyboard has both trigger and > gate, so is > it even needed at this point? > > So, seems it would be: > > 1. J2 to Trigger in > 2. J1 White to Gate in > 3. J4 to minus out > 4. J3 to plus out > > > Thanks.... > > Les Mizzell > > - - - - - - - - - - - - - - - - > Some days you're the dog; > some days you're the hydrant. > - - - - - - - - - - - - - - - - > > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > >
2002-03-01 by mmarsh100
I'm not using any banana jacks, and if I did I would use the 940. I personally prefer 1/4"... Mike --- In motm@y..., "Les Mizzell" <lesmizz@b...> wrote: >... > > Surely I'm not the only person in the world that's putting banana plugs on a > MOTM. > > Or am I? > > > Les Mizzell > ...
2002-03-02 by jwbarlow@aol.com
MOTM.
Or am I?
2002-03-02 by Les Mizzell
> What are you interfacing with? My main system is Modcan. > If you really want to add bananas to the 800, I think I can look > up my old stuff and let you know what I had done and what it did Please! I do understand the problems with converting normalled connections over to bananas, and am sure I will make many mistakes along the way. It's been awhile since I've built any kits (think PAIA when they first started...damn am I getting old!) I gave serious thought to using the Converter panel, but as mentioned before, I'd almost need 1 panel for each 2 modules I want to interface. If I get to a point where I *have* to build special cables or use the patch panel, I will, but I feel that restricts flow when patching and will go to great lengths to avoid that. Thanks for you offer to help. Looking forward to seeing what you did to your 800s. I'm slowly working on a section of my website for the trials and tribulations of assembling a modular. I'll be adding the mods that I'm having to make to panels as I go along as well. The main MOTM modules currently being considered are 4 800s. While Modcan has a GREAT VC ENV, but I don't need a $200 VC ENV for everything! So I'm filling out some there. Will probably add 2 quad LFOs as well shortly. Will mod those with CV inputs for each LFO instead of the normalled connections. Can't wait to see the configuration of the "Envelope Nest" 500 module! Les Mizzell - - - - - - - - - - - - - - - - Some days you're the dog; some days you're the hydrant. - - - - - - - - - - - - - - - -
2002-03-04 by Les Mizzell
Afternoon, Getting ready to order a 410 Triple Res Filter... Has anybody done mods to allow: A. Separate VC Control of each LFO? B. Separate outputs for each LFO? C. Additional VC input for each filter to allow control from an external source like an EG or S/H? Note: I didn't mention banana jacks even ONCE! Les Mizzell - - - - - - - - - - - - - - - - Some days you're the dog; some days you're the hydrant. - - - - - - - - - - - - - - - -
2002-03-05 by George Kisslak
check out: Oakley OMS-410 companion module http://www.oakleysound.com/oms-410.htm ----- Original Message -----
From: Les Mizzell <lesmizz@...> To: <motm@yahoogroups.com> Sent: Monday, March 04, 2002 4:27 PM Subject: [motm] Anybody done 410 Triple Res Filter Mods > Afternoon, > > Getting ready to order a 410 Triple Res Filter... > > Has anybody done mods to allow: > > A. Separate VC Control of each LFO? > > B. Separate outputs for each LFO? > > C. Additional VC input for each filter to allow control from an external > source like an EG or S/H? > > > Note: I didn't mention banana jacks even ONCE! > > > Les Mizzell
2002-03-05 by keithw@cix.co.uk
In-Reply-To: <NDBBIKBKOLEPPMGPODEHEELILCAA.lesmizz@...> err well yes! The Oakley OMS 410 companion module. see: http://www.oakleysound.com/ :o) Keith http://home.freeuk.net/lowpass
2002-03-05 by mate_stubb
>>>> Has anybody done mods to allow: A. Separate VC Control of each LFO? B. Separate outputs for each LFO? C. Additional VC input for each filter to allow control from an external source like an EG or S/H? <<<< Les, Almost everything you ask for is available from Oakley: http://www.oakleysound.com/oms-410.htm Larry and I make a Stooge panel for this module, lots of satisfied customers. http://www.wiseguysynth.com/larry/panel.htm Moe
