Stooge Panel?
2002-03-07 by sucrosemusic
Just curious, any possibility of making a stooge panel for the Metasonix TM-1 module? The thing will fit behind a 2U panel, barely, and will probably work OK with mounting brackets. (The beam tube is the issue, it's very close, but that can be worked with) Anybody here had any experience with a TM-1? I've used one in a sort of normal setup (I don't own one, but spent some good time with one) but never in a modular. What do you folks all think of integrating it more closely with the MOTM setup?
