Re: Woodworking
2002-03-07 by paulhaneberg
As owner of a woodshop, my advise would be to stay away from solid wood except for trim. If you use solid wood you have to worry about pieces which are joined together expanding and contracting at different rates, you have to worry about warpage as well. I'd suggest using a high quality veneered plywood. You can get cabinet grade plywood with cherry or mahogony veneer which will finish beautifully. Buy a few strips of solid wood to use for exposed edges. Use solid pieces if you are going to have curves or fancy moldings. For finishing stain if desired first, then use polyurethane if you are going to brush it on or catalized lacquer if you are going to spray. If you are going to apply your finish by hand and using polyurethane, thin it out first and brush it on using a nylon stocking (wear gloves.) The combination of the thinning and the stocking will eliminate bubbles. Apply several coats. Wait until each coat drys but don't wait over 24 hours. Remove imperfections with very fine steel wool or wet sandpaper. Alternatively you could use an oil type finish. This is easier to apply, but can dry out and isn't as resistant to scratching.
