Re: [motm] MOTM-450 peek
2002-04-15 by jhaible@debitel.net
>As far as the electrical design is concerned, if you are keeping the bypass >switch, a 9th knob for MAKE-UP GAIN should then be added as well. >Otherwise, there is no point in having a bypass switch because making >comparisons without matching the levels is impossible!! Look at any EQ >with a bypass switch. If it's going to have a bypass feature, it needs a >pot for make-up gain. Having one without the other looks retarded. You don't really need a pot for makeup gain, because you can do this with the 10 existing pots already. (All 10 pots up can be more than unity gain, and as I said before, all pots at 7 is the same sound as all pots at 8, just the level is different. (I see that an extra gain knob, though redundant, would further simplify A/B switching, but that's a bit of an overkill IMO.) >I realize that motm is not intended as meat and potatoes gear. Yet, >equalizers with a unique sound often become desirable, even legendary, >pieces of recording equipment. I've never seen a Moog used that way, but >that doesn't mean it's never been done. Perhaps the Moog was too noisy. >Thirty years ago, most solid state did not sound good. Considering what it >takes to rackmount many popular board modules, mounting two synth modules >sideways and finding a +/-15 supply is nothing. This MOTM module will be a circuit which I have first built for myself, and the funny thing is that I actually put my version into a 19" 1U enclosure to use it with either MOTM or in another rack with other gear. Maybe that's why I told Paul that a Bypass switch is crucial, and maybe it's in there for just that reason. I just like to hear the difference (and it was usefull to for creating the demo sounds, too. (;->) ) But yes, the Moog original is without Bypass switch, too. So obviously one can live without it. And I like the idea of running direct signal and filtered signal to a mixer, or to the VC crossfade VCA, whatever. Just keep in mind that if the module has no bypass switch, and if you want to patch a bypass configuration, this would mean considerable extra effort. JH.
