Re: Grids, Layouts, Ergonomics
2002-04-15 by rogerpellegrini
I apologize if this going over old ground, and I understand I may be invoking the wrath of the devoted, but in my humble opinion, the rigid grid MOTM panel design is a considerable drawback to the system. My opinion is that the Moog design approach (or to differing degrees the design of Arp 2500, Cirocco modulars, or Polyfusion systems) is superior in that anyone familiar with the modules can identify functions easily from a distance, a goal of good human interface design. To my eye, for example, no two Moog modules look alike, whereas (nearly) all the MOTM modules do. Look at the dashboards of well-designed cars and you will see differently shaped and sized buttons whose functions relate to their appearance and can be identified from a distance by a driver whose attention is (mostly) elsewhere. Those dashboards with rows of identical buttons are criticized in the automotive press. To put this in context, I use a medium-sized modular Moog augmented with a smattering of modules from MOTM, Synth.com and Blacet. I've also designed a few panels of my own over the last 20 years. Recently, faced with the choice of purchasing Mixer, Noise and Sample & Hold modules, I chose the Synth.com modules over the MOTM modules, simply from an ergonomic standpoint, and despite the superior specifications of the MOTM offerings. I truly do like the MOTM modules I currently have, and will purchase more, but there is room for improvement in the interface design. In any case, please consider the advantages of "varying the grid", allowing for different knob types, and functional layout choices when considering new panel designs. And thank you in advance for being open minded enough to consider other points of view.
