MOTM
MOTM-190 Mock-up
MOTM-190 Mock-up
2002-07-14 by Paul Schreiber
Comments?
It's a little tight in the labelling department, but this is the general idea.
Paul S.
Re: MOTM-190 Mock-up
2002-07-14 by mmarsh100
A couple of comments/questions:
1) There are two VCAs but they can only be controlled together,
correct?  I mean if you flip the switch to RM, then both will be RM
and if you change the GAIN knob it affects both VCAs?  Or is one VCA
RM-able and the other exponential?  Still, GAIN and CV MOD affect
both equally, no?
2) What about push/pull switches on the pots instead of toggles?
Mike
--- In motm@y..., "Paul Schreiber" <synth1@a...> wrote:
> Comments?
general idea.
> Paul S.
Re: [motm] MOTM-190 Mock-up
2002-07-14 by thomas white
Looks great to me but a full description of the features would be handy to
figure out exact uses and design quirks. Any help in this area? Boy this
will really help my polyphony plan out big time. Thanks and I look forward
to the feature run down.
Thomas White
>From: "Paul Schreiber" <synth1@...>
>To: "MOTM listserv" <motm@yahoogroups.com>
>Subject: [motm] MOTM-190 Mock-up
>Date: Sun, 14 Jul 2002 12:49:18 -0500
>Comments?
>idea.
>Paul S.
><< m190.jpg >>
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
2002-07-14 by vulture.squadron@syol.com
idea.
hello all,
couldn't the switches go below the three pots, imho they'd sit a little more
comfortable there
cheers
paul b
2002-07-15 by edibennardo
I perfectly agree, the switches below the pots might be better looking
if this is phisically possible.
Enrico Italy
> idea.
> hello all,
> comfortable there
> cheers
> paul b
