MOTM
MOTM-190 features
MOTM-190 features
2002-07-14 by Paul Schreiber
The 2 VCAs are totally independent (they are not even connected to each other).
The top-most knob is a little freaky (and hard to label), because it has 2 *different* functions.
In RM mode: The pot is like a "Dry/Wet" blend on a '410. Fully CCW, the output is the input (a
wire!). At 12'oclock, it's AM, and at full CW, it's RM.
In VCA mode: The pot acts like "Initial Gain" on a '110 BUT, the circuit uses a 'trick' so that
the pot setting PLUS the incoming CV is normalized to *unity* gain.
Example with ADSR input (0 to +5V):
a) Fully CCW, the output = the input (a wire again!)
b) at 12 o'clock, the gain goes from 0.5 to 1.0 Now this is a little strange, as it won't gate
the audio off/on (like it would if the gain was say 0 to 0.5).
c) fully CW, the gain goes from 0 to 1 (I would call this 'normal VCA operation')
It was dones this way to save 1 pot position, and to offer the AM/RM blending feature. Rather
than the '110 that has 1 VCA and 1 RM that makes a so-so VCA, the '190 has 2 good VCAs AND a good
RM. This one funky control is hard to "get your head around" until you use it. In VCA mode, you
just turn the pot all the way around and it behaves as you expect. Same with RM. Most times, the
pot will sit over fully CCW. But in RM mode, it does sound uniquely different than other RMs you
may have heard.
Paul S.
Re: [motm] MOTM-190 features
1 more thing: the top pot is for VCA/RM #1.
The middle and bottom pots are for VCA #2.
Better labelling ideas welcome.
Paul S.
RE: [motm] MOTM-190 features
2002-07-15 by John Loffink
Top knob:
0 position = IN
5 position = AM
10 position = RM/CV1
Second Knob label = GAIN2
Third Knob label = CV2 MOD
John Loffink
jloffink@...
2002-07-15 by Paul Schreiber
The switches below would interfere with the jacks and the patch cords would get in the way.
Paul S.
Sent: Monday, July 15, 2002 8:04 AM
Subject: FW: [motm] MOTM-190 features
I agree, something more along the lines of this suggestion would be helpful.
I also agree with the desire to put the switches under the pot column, unless that's physically impossible. If they switched sideways instead of up and down, would everyone freak out? You could at least fit one down there that way.
Top knob:
0 position = IN
5 position = AM
2002-07-15 by groovyshaman@snet.net
I like this labelling better.
Ah, don't shoot me, but maybe this would look cleaner in 2U.  I know, I
know, this is 'supposed' to be a uModule... it's just that with the
indefinite delay of the 2U 130 and the disco'd 2U 110, a 'relaxed-fit' 2U
VCA would be nice. <grimace>
George
To: 'Paul Schreiber' ; motm@yahoogroups.com
Sent: Sunday, July 14, 2002 11:23 PM
Subject: RE: [motm] MOTM-190 features
Top knob:
0 position = IN
5 position = AM
John Loffink
jloffink@...
