MOTM
Re: sequencing MOTM with SH101
2002-07-21 by robs7@aol.com
just reconfirming what everyone else has said. The gate out needs to go to an 800 first.
If I rememebr correctly (I prefer my MOTM to be controlled via midi-cv converter played from larger keyboard), the differences between multi and single note triggering do not matter. There must be an issue with last note/low note priority, but I forget how that worked out.
The arpegiator does NOT send out new gate signals with each arpeggiated note, but the sequncer does. Plus (!) if you take an output from a 320 and run it into the clock input of the SH-101, the MOTM LFO will be the device guiding the speed of the arpegiator and sequencer. while this is not earth shattering news, the point is that it will actually work! the sh-101 can be very interesting to use because the sequencer does transmit gates. you can run the sequencer and only take the gate output!
