Quantizer Question
1999-10-03 by Tkacs, Ken
Is there any way of making a quantizer that has a "softness" control? In other words, there would be an option where the steps are not completely discreet-the output voltage tends to "pull" the input CV to the quantized steps, but there is a softer knee? The reason I ask is that I've always wondered if a quantizer might help make a Theremin controller a bit easier to manage. But one wouldn't want to completely lose the Theremin's 'melismatic' nature. Could it be something as easy as leaking a bit of the input CV into the output? I guess you could slap an integrator on the quantized output to force a glide, but that's not the same. Does any of this make sense? By the way, regarding microtonality, \ufffd-tones are actually pretty nasty. They just multiply the problems with 12-tone equal temperament by two. If you want to try a good-sounding, manageable microtonality, try 19-tone ET. Compared to 12-tone ET, you sacrifice a little bit of accuracy on one or two intervals, but pick up a lot on the others. You can pretty much map the chromatic scale onto it with 7 extra notes added.
