MOTM
fixed filter bank! yay!
2002-12-03 by celesteh@casaninja.com
Oft I had requested a fixed filter bank and now I see that it is one of
the new panels.  yay!
I was reading the description, tho, and I'm not 100% clear on the
behavior.  The desc says that it's not like a graphic EQ, but then goes on
to state that all the knobs set at 10 sounds just like a wire.
I was under the impression that filters were not flat, they created bell
curves around their center frequencies, so not everything in the freq
range was filtered equally.  So a FFB, with everything set at 10 would not
sound like a wire (vs an EQ, which would), but would instead sound like a
whole bunch of bandpass filters so that the center frequencies would all
be emphasized and the sound would be colored by passing through the FFB.
So, colored or not?
Also, anybody in the SF Bay Area planning on ordering one?
thanks,
celeste
Celesteh@...     http://www.casaninja.com/celesteh
                                 http://www.mp3.com/celesteh
Re: [motm] fixed filter bank! yay!
2002-12-03 by Paul Schreiber
> So, colored or not?
Well, I over-simplified. More like a 'rippled wire' response. I'll post some plots tomorrow. The
point I was trying to make is that the behavior if the MOTM-450 is *not* what most people are
used to (EQ cut/boost). It doesn't cut OR boost.
Paul S.
RE: [motm] fixed filter bank! yay!
2002-12-03 by Chris Walcott
My reading of this was that the filterbank only cuts which would mean that when everything is at 10 there is no eqalization taking place.
Maybe I'm wrong though.
- chris
Sent: Tuesday, December 03, 2002 12:56 PM
To: motm
Subject: [motm] fixed filter bank! yay!
So, colored or not?
thanks,
celeste
very groovy!
a mp3 of some white noise running through it would clear things up too :)
2002-12-03 by Neil Bradley
> > So, colored or not?
> post some plots tomorrow. The point I was trying to make is that the
> behavior if the MOTM-450 is *not* what most people are used to (EQ
Hm... well, maybe I'm a clueless idiot when it comes to modular gear, but
if it doesn't cut or boost, what DOES it do?
-->Neil
Neil Bradley            In the land of the blind, the one eyed man is not
Synthcom Systems, Inc.  king - he's a prisoner.
ICQ #29402898
Re: fixed filter bank! yay!
2002-12-04 by Mike Marsh
No, no, not clueless! Paul is sometimes, ehem, *obtuse*.  Each
filter in the bank pass only a certain range of frequency. It
neither boosts nor cuts that frequency range.  It does in a
sense 'cut' all frequencies around it; it's a band-pass filter.  The
whole thing is a collection of band-pass filters tuned to different
frequencies.
Except the low pass and hi pass knobes: these filters are low pass
and high pass respectively.
Hope that clears it up!  And I further hope I got the explication
correct...
Mike, who neatly sliced the tip of his thumb off while scalloping
potatoes for Thanksgiving dinner.
--- In motm@y..., Neil Bradley <nb@s...> wrote:
> > > So, colored or not?
I'll
(EQ
gear, but
> -->Neil
is not
> ICQ #29402898
2002-12-04 by jhaible
> So, colored or not?
*Very* coloured.
Even without pots ( = all pots at max) this would be a
usefull device to "colour" a sound. And the colour
is "Moog". With the uVCF and the Filter Bank you have
two of the most important pieces to create that "Moog
Color".
(I'm regularly running my CS-50 thru the prototype,
and it's astounding how much it can change the character
of an instrument.)
JH.
cut AND boost. (;->)
There's a lot of weird interaction between the channels, which gives
the desired coloration effect.
JH.
2002-12-04 by Brousseau, Paul E (Paul)
Hmm, what kind of wacky doublethink have you got there...?
--PBr
Sent: Tuesday, December 03, 2002 4:34 PM
To: Neil Bradley
Cc: motm
Subject: Re: [motm] fixed filter bank! yay!
