MOTM-100 clicks & pops
1999-10-07 by Paul Schreiber
Yes, TJ is correct: the LF398 chip switches the output in like 100ns and some modules will not like this. As it turns out, I need to re-tool the front panels anyway. So, I can add a panel pot to add slew and a switch to select vibrato mode. Both of these can be done but what will happen is I will go to a MOTM-101 and have to raise the price $10 to cover the added costs. I will have to redo the pcb but this is minor. The slew rate mod does require an additional op amp so adding this to current modules is difficult. There is a VC lag in design now that will work (although over-kill). Paul S.
