Re: Digest Number 219
1999-10-07 by mark scetta
thanks for the backup, TJ! i tried a 0.1uf axial ceramic "104" cap soldered from MOTM-100's OUT ground to tip and am still getting the pitter patter of little feet.... should i try another cap or am i not wired right? mark
>Message: 10 > Date: Thu, 7 Oct 1999 00:34:52 -0500 > From: "Paul Schreiber" <synth1@...> >Subject: Paging Rocket to MOTM-100 lab!! > >Looking at schematic: I suspect that a 0.1uF cap across the output terminals >(just solder it across the OUT jack's lugs) will get rid of the pops. No >buffer needed. >This is a kluge but should work. Really, I suspect *any* NONPOLAR cap from >0.1uF to 1uF >will work. > >However, a variable slew is fun, too. I had this on my first homebuilt >modular. Freaky. > >Paul S. >just finished MOTM-410 manual, so off to bed!! > >PS: hey TJ! liked the audio, pops and all. How much was MOTM generated??!? > >
