MOTM-850 questions
2003-01-31 by osthelder <osthelder@netscape.net>
Rather than bug Paul, who is busily putting together my kits as you read this, I thought I'd solicit information from the group about the MOTM-850 pedal interface. I'd like to abuse it, of course, but could someone tell me what type of input (voltage and connections) it needs? I have no familiarity with the control pedals that would normally be used. Thanks! Chub
2003-01-31 by Mike Marsh <mmarsh@websense.com>
As with all other MOTM modules, this one does respond favorably to abuse :) I use it mainly with a Roland EV-5 pedal. I don't have the info in front of me regarding voltages, but I think that's on the site. Some people hate the Roland pedal and prefer the Yamaha pedal (model number escapes me). Some people have modified the 850 to interface with a joystick. I think taht info is on Stooge Larry's (the designer of the original concept) site. Search this list's archive for lots of info on the 850 and pedals. One more cool thing about the 850: it's a gate source! So you could do stuff like bring in another timbre by stepping on the pedal simultaneously to controlling a CV. Pretty cool! Mike --- In motm@yahoogroups.com, "osthelder <osthelder@n...>" <osthelder@n...> wrote: > Rather than bug Paul, who is busily putting together my kits as you > read this, I thought I'd solicit information from the group about the > MOTM-850 pedal interface. I'd like to abuse it, of course, but could
> someone tell me what type of input (voltage and connections) it > needs? I have no familiarity with the control pedals that would > normally be used. > > Thanks! > > Chub
2003-01-31 by J. Larry Hendry
Since the input on the 850 came from my circuit, I'll answer this. The pedal input on the 850 will accept one of three different types of inputs. 1. CV from a pedal that does the 0 to whatever voltage. Use the 850 to scale / offset / mix / gate extract from a plain CV pedal or other CV. 2. pot type pedal with wiper wired to ring. 3. pot type pedal with wiper wired to sleeve. The input circuit is set up to work with both these wiring arrangements (2 and 3 above) on a TRS style jack. I have a free bracket (your size choice) and free shipping of bracket to the first listmember to guess / figure out how that works. The bottom line is the two possibilities for pedal wiring TRS jacks (Yamaha uses one and Roland uses the other) both work with the 850 without wiring changes. And, a 1/4 mono jack (as in any CV from pedal or otherwise) works too. The 850 is set up standard to accept 3 common pot sizes. 8.5K (just happens to match Roland EV-5) 50 K, just happens to match Yamaha FC-7 and 100K. Any pot size can be accommodated. A simple resistor change is needed for other sizes to maintain the exact scale on the output. For 8.5K = Roland, set the jumper to "R", for 50K = Yamaha, set to "Y." for 100K, simply remove the jumper. Larry
----- Original Message ----- From: <osthelder@...> To: <motm@yahoogroups.com> Sent: Friday, January 31, 2003 7:56 AM Subject: [motm] MOTM-850 questions Rather than bug Paul, who is busily putting together my kits as you read this, I thought I'd solicit information from the group about the MOTM-850 pedal interface. I'd like to abuse it, of course, but could someone tell me what type of input (voltage and connections) it needs? I have no familiarity with the control pedals that would normally be used. Thanks! Chub Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
