Power supply wiring issues -longish
2003-02-10 by J. Larry Hendry
This may be nothing but rehashing something many of you already know. And, I am not an expert on the subject. But, I promised I would offer my thoughts on this subject a while back. Having said that, I am going to offer a simple observation and apply ohms law to power supply DC wiring and wire size in a simple exercise. Please see the attached PDF file for the drawing I refer to in this discussion. I apologize for sending an attachment to list mail. But, it is only 5K, so I figured no one would mind. In this drawing, I will assume that the power supply has a regulator which is regulating to the power supply voltage at the power supply and not making use of remote sensing. Some modules (in particular that ones that have LEDs) vary in the current that they draw from the power supply. Other modules are somewhat sensitive to fluctuations in power supply voltage. Let's take one of each for this example. Ohm's law tells us that anytime we have current flow across resistance, we have voltage drop. We know that all the components of our power supply wiring have resistance. We are going to look at ONLY the resistance of the wire. If we look at the drawing, we can assume that the voltage at the PCB is lower than the voltage at the power supply by this amount: E drop (wire A) = I (module left) + I (module right) x R (wire A). The voltage at each module is also lower than the voltage at the PCB by this amount Module left: E drop (wire B) = I (module left) x R (wire B) Module right: E drop (wire C) = I (module right) x R (wire C) To find the voltage drop in the wiring to each module from the point of regulation (the power supply), we have to add the voltage drops: For module left total drop from the power supply: E drop (wire A) + E drop (wire B) For module right total drop from the power supply: E drop (wire A) + E drop (wire C) About now, you are probably cursing me for stating the obvious. But, I wanted it to be clear that current from one module effects the voltage delivered to a different module. See that voltage drop to module right = [I (right) + I (left) x R (wire A)] + [I (right) x R (wire C)] And, varying current produces varying voltage drops. So, in our example, we see that varying load in module left is causing varying voltage to be delivered to module right. That is going to occur, no matter what we do with wiring. Our task is to minimize that to a negligible amount. Since we have only 2 modules in the drawing, I am going to put some out-of-proportion numbers in the formula to make a point. module left I minimum = 20 mA; maximum = 50mA module right I = constantly around 30 mA Voltage (+15) we will look at only one leg resistance wire A, B and C all = 2 ohms Voltage at PCB (I left min) = 15 - [(0.02 + 0.03) x 2] = 14.9 volts Voltage at module left = 14.9 - (0.02 x 2) = 14.86 Voltage at module right = 14.9 - (0.03 x 2) = 14.84 Voltage at PCB (I left max) = 15 - [(0.05 + 0.03) x 2] = 14.84 volts Voltage at module left = 14.84 - (0.05 x 2) = 14.74 Voltage at module right = 14.84 - (0.03 x 2) = 14.78 Delta E module left = .12 volts (.08%) Delta E module right = .06 volts (.04%) 50% of delta E (left) So, even though module right has a constant load, it is seeing a fluctuating supply voltage because of the varying voltage drop across wire A caused by the varying load of module left. The problem is that wire A, B and C all have the same resistance. So, voltage drop from each module is imposed equally across its own power cable and the power cable that supplies the PCB (wire A in this case). The solution, is to lower the resistance of wire A so that a larger percentage of the varying voltage drops is found across the individual module power supply wire. Interaction between modules is then reduced. Let's change the resistance of wire A from 2 ohms to 2/10 ohm and look at these numbers again: Voltage at PCB (I left min) = 15 - [(0.02 + 0.03) x 0.2] = 14.99 volts Voltage at module left = 14.99 - (0.02 x 2) = 14.95 Voltage at module right = 14.99 - (0.03 x 2) = 14.93 Voltage at PCB (I left max) = 15 - [(0.05 + 0.03) x 0.2] = 14.984 volts Voltage at module left = 14.984 - (0.05 x 2) = 14.884 Voltage at module right = 14.984 - (0.03 x 2) = 14.924 Delta E module left = .066 volts (.044%) Delta E module right = .006 volts (.004%) 9% of delta E left Notice how lowering the resistance of the wire A has reduced the delta E to module right caused by the varying load of module left. Or, to say it more easily, module interaction due to power supply coupling has been reduced. Now, these numbers are a little out of whack as the resistance of our power wires was exaggerated some to make a point. But, now we see the importance of using LARGE wire between the power supply and the distribution PCBs. This wire should represent the smallest portion of resistance in the wiring between the power supply and the module. I always use # 12 or 14. Sorry to have boar those of you to whom this discussion is elementary. However, this question comes up frequently, and I hope this helps someone understand why the wire to the distribution point has to be sized for something other than it loadability. Larry H I'm tired., so forgive me if I have a slight math error along the way. That does not change the conclusion.
