MOTM
MOTM-320 VCLFO Modification Advice Needed
2003-02-09 by Michael <dmichaelt2001@yahoo.com>
Hello MOTMers,
Seems like most everyone adapts smaller modules to fit the larger
MOTM format but here's something different...
I'd like to adapt an MOTM-320 VCLFO to fit into a FracRak.  Since the
FrakRak is only 5.25" in height I'll need to mount the short end of
the PCB onto the new front panel (whereas the original MOTM front
panel has the long end of the PCB mounted to the front panel).  This
means I'll need to remove the pots from the PCB and remount them onto
the new face plate then attach them to the PCB with flying wires.
I'd like to use the original pots if possible.  My two questions are:
Can I do this without hindering the performance of the VCLFO?
What would be the best gauge wire to use for the flying wires?
Thanks in advance,
Michael
RE: [motm] MOTM-320 VCLFO Modification Advice Needed
2003-02-09 by John Loffink
Flying wires will not affect the performance.
22 AWG stranded is a common wire size for this type of wiring.
John Loffink
jloffink@...
