Does anyone know of a wood screw part that looks similar to the
machine screws that Paul provides for mounting the modules?
If you want to use a wood screw that exactly matches the head of the MOTM
mounting screws, the you need to get a # 8 screw, you need to get a phillips
drive, a pan style head, and a black oxide coating.
I went to my favorite source for any type of screw:
http://www.aaronsgeneralstore.com/
Selected the "self tapping screw" (same as I supply with the SKB backs).
I used the search feature for a 1/2" long screw with the criterial I
specified above and found two:
http://www.aaronsself-tappingscrews.com/cfusion/DisplayProduct.cfm?ITEM=1013
ST1232
ST2200
Officially, these are sheet metal screws. But, I prefer sheet metal screws
to wood screws in many applications.
One is 15 and the other is 18 threads per inch. If you want a different
length, you can run the search yourself. I get all my flat rails screws
from the "machine screws" division of Aaron's.
Larry Hendry
