MOTM
Horizontal Module Mounting
2004-01-26 by alt-mode
Howdy,
Has anyone ever mounted MOTM modules sideways using the standard rack
rails?  For example, you could take advantage of the 2U available at the
bottom of a 12U SKB pop-up case by mounting two 2U modules sideways at the
bottom.  I'm thinking of mounting an Expressionist breakout panel and a 940
patch panel in a non-MOTM area of my studio.  The 940 is very useful in
places away from my MOTM...
	Eric
Re: [motm] Horizontal Module Mounting
Yes, I pulled a 940 out of the rack to see and you are correct.  What is
needed is a set of brackets, one for each end  and one for the space
between the modules.  These would have to stiff enough to limit the flex of
the joined panels.  Perhaps a raised section that would wedge against the
edge of the panels to limit flex.  A possible Stooge metalworks product????
         Eric
At 09:25 PM 1/25/2004 -0600, J. Larry Hendry wrote:
>It won't work without cutting the rack rail.  The lip that normally resides
>behind the module at the top and bottom (where Paul reserved 1/2 inch in the
>layout) will interfere with the jacks and PCB mounting.
>If you were willing to do some heavy cutting / grinding on the MOTM rails,
>you sure could.
>Larry
>----- Original Message -----
>From: alt-mode <yahoo@...>
>To: <motm@yahoogroups.com>
>Sent: Sunday, January 25, 2004 8:09 PM
>Subject: [motm] Horizontal Module Mounting
>Howdy,
>Eric
>Yahoo! Groups Links
>To visit your group on the web, go to:
>  http://groups.yahoo.com/group/motm/
>To unsubscribe from this group, send an email to:
>  motm-unsubscribe@yahoogroups.com
>Your use of Yahoo! Groups is subject to:
>  http://docs.yahoo.com/info/terms/
2004-01-26 by J. Larry Hendry
you sure could.
Larry
Howdy,
Eric
Yahoo! Groups Links
I'll put this in the same category as the 2U high tall panels I had planned
for SKB cases and SKB backs.  There is simply not enough interest to make
any quantity of these.  I have a stack of SKB backs in my garage to prove
it.
What I think would be better is making more room by putting the power supply
and a set of mults in that 2U of space.  They could be standard mults or 940
style stuff.  But, even when I bring this up, I hear from 3 or 4 people
tops.
Larry
To: J. Larry Hendry <jlarryh@...>; MOTM List <motm@yahoogroups.com>
Sent: Sunday, January 25, 2004 8:47 PM
Subject: Re: [motm] Horizontal Module Mounting
         Eric
>you sure could.
>Larry
>Howdy,
>Eric
>Yahoo! Groups Links
