MOTM
MPC4000 sound quality for MOTM?
2004-02-07 by Robert van der Kamp
I asked before on AH, but didn't get a concrete answer:
I'm thinking of getting an MPC4000, for midi sequencing of
course, but mainly to be able to make samples of my MOTM
synth and use these to build a song.  (I hate computers for
that kind of creative stuff.)
I know the 4k has a bad reputation, but that's not what I'm
asking about here (working on that). What I'd like to know
is if the sound quality of the 4k at 24bit/96k is good
enough to capture the beautiful analog quality of my synth.
I assume that 96k will be good enough to deal with most of
the aliasing problems, but is the AD/DA good enough?
Transparent? No colouring? That kind of stuff.
Did anybody ever hear the machine?
Robert
Re: [motm] MPC4000 sound quality for MOTM?
2004-02-08 by Jim Black
I think the suggestion to use a front-end A/D for the
MPC is dead-on. I, personally, do not run the MOTM
direct into the A/D, but that is me. It is easier to
run it thru the desk (a mixer or if you don't have
one, a preamp).
Some folks I've worked with insist on a tube front-end
(Manley) as they insist an analog synth direct to disk
or direct-in is as stupid as running any line-level
instrument direct.
I always thought the virtue of the MPC was the *tight*
MIDI timing for sequencing. No software sequencer can
touch it. That, and the obvious great tool for
songwriting, pre-prod, et.c
Back in the day, I used to do what you describe...
everything analog pumped thru an Akai Sampler before
being sent to tape. Definitely speeds up the process!
> answer:
> sequencing of
> MOTM
> computers for
> what I'm
> to know
> good
> synth.
> most of
> Thanks,
> Robert
Do you Yahoo!?
Yahoo! Finance: Get your refund fast by filing online.
http://taxes.yahoo.com/filing.html
Re: MPC4000 sound quality for MOTM?
2004-02-08 by rreprobate
> instrument direct.
Bah. In most cases, yes. Most synths, from old stuff on up to today's crap
have quite wimpy output stages. For most stuff, a DI or line driver makes a
huge difference. However, the chip usually used as an output buffer in the
MOTM (the OP275), is much better at driving a wire than what most synths
are using.
Of course, if you have a long cable run it's a good idea to balance your
output, but that's a different issue.
That said, I still almost always use the DI input on a Manley mic pre too.
Chee!!
Max
2004-02-08 by Robert van der Kamp
> one, a preamp).
Okay, so I seems I need to find an Apogee A/D and use it all
the time.
> instrument direct.
Whoa! This is a surprise for me.
Are you saying that my mixer isn't enough to prep an anlog
instrument for recording on digital media?
Or suppose I would get that front end AD, would it be unwise
according to your sources to connect the MOTM (or other
analog synth's) output directly to the AD?
I normally work with a mixer, and redirect the signal I want
to sample to one of the mixer's output busses, which are
connected to my samplers. Will that do?
This is what works best for me. I get to play with phrases
of recorded instruments and trigger them like you would
trigger drums. And I don't have to use a computer for
that. :)
- Robert
2004-02-08 by simon@austarmetro.com.au
> one, a preamp).
Why not just run it straight into the MPC?
The MPC has a level control to set the gain right, so it has an inbuilt preamp stage.
>  instrument direct.
Why is it stupid? Doesn't it depend on how the recording device handles gain, or doesn't in some cases?
You are worried about sound quality and needing 96KHz/24bit, but you are going to run the signal through a mixer anyway?
If the AD only has balanced +4 line inputs, but it depends on what you are plugging into and how it handles different level signals.
Yes, but why not avoid the mixer, buses, etc., and just plug straight into the MPC?
Why?
> that. :)
Simon
Canberra
AUSTRALIA
Gang.
The instrument input on a high-end pre-amplifier very often improves the
sound of a synth because it presents a significantly higher input impendence.
It's not really about the gain.
Something like the line-in on a Mackie has an input impedence of 10k or so,
which is adequete for most line level signals like MOTM, which are usually 1k.
However, the input impedence on a nice pre-amp's DI input can be 2 or 3
orders of magnitude higher than the Mackie. This makes it easier for a synth
with a less than beefy output to drive the wire. Audibly, it results in a crisper
high-end and tighter bass.
But I re-iterate that the output buffer on the 190 vca or the 820 mixer does
pretty good even with a line input with a 10k impendence or so. Going
through a DI just makes it that much better. We're talking about gear with input
transformers that cost $150 a pop, and often discrete transistor or even tube
output buffers.
I have no idea what kind of input is on the MPC these days, but the old ones
were a sort of "universal" pre-amp with a wide ranging gain control. These
kinds of amplifiers tend to be "ok" but not really stellar on any kind of source.
Using an outboard pre-amp and converters and making a digital connection
to the MPC will allow you to be more choosy with the kind of coloration you're
applying to all of your samples on the way into the box. But now we're getting
into like... which ward do you want to stay in? Blue or white pajamas?
I hope that helps.
Max
> >  instrument direct.
2004-02-09 by Jim Black
Oh, absolutely! As others have posted... gain is not
an issue with our MOTM. At issue is the A/D conversion
of the MPC. Is it of the level of an Apogee, Mytek,
etc.? I dunno... that's ur call. I know folks using
MPC-60s!
Yup... again, quality of a Manley... probably not, but
we all don't have Manley's in our racks! i don't know
the impedence of the MPC - it may need a DI.
> cases?
Gain and impedence. I think the relevance is that
folks should think of synthesizers like any other
line-level instrument. You see... alot of engineers to
this day are of the "direct into the board" when it
comes to synth's. If you have 6-8 tracks of guitars -
it probably doesn't matter, u ain't gonna hear it. If
your more of an "electronic" act... well...
> signal I want
> which are
Of course! Not as clean/direct as the DI/Preamp/EQ
signal chain.
YMMV.
Do you Yahoo!?
2004-02-09 by Robert van der Kamp
Guys, would this Apogee preamp/ADC unit do the job? It has
both a preamp and AD built it, but I don't know if the
specs of the preamp are good enough to deal with delicate
analog signals, as you described it. The specs say the
impedance is 10k, which is not spectacular, right?
http://www.apogeedigital.com/products/minime.php
- Robert
2004-02-10 by Chris Walcott
A buddy of mine has one of these and really likes it.  He also uses it
as his clock in a MOTU system.  Made a huge improvement.
- chris
>  - Robert
> 	• 	To visit your group on the web, go to:
> http://groups.yahoo.com/group/motm/
> 	• 	 To unsubscribe from this group, send an email to:
> motm-unsubscribe@yahoogroups.com
> 	• 	 Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service.
