MOTM
? on restricting negative voltage input
2004-04-16 by Jeffrey Pontius
To the experts (which is most everyone here but me),
I working with a small circuit that I would like to add voltage control
(e.g., lfo, env.) through an attenuating pot.  When negative voltages
(e.g., from an lfo waveform) enter the circuit they 'screw things up'.  Is
there a "simple" way to restrict the incoming voltages to positive
voltages only?
Thanks, Jeff
Re: [motm] ? on restricting negative voltage input
2004-04-16 by Scott Juskiw
>voltages only?
>Thanks, Jeff
Simplest way is to use a diode. But you may still get a small
negative voltage equal to the diode's forward voltage drop, around
0.65V. Can your circuit handle a small negative voltage of -0.65V?
2004-04-17 by Richard Brewster
Either a half or full-wave rectifier will do it.  For a half-wave
rectifier circuit, look at the CV processing circuit on Ken Stone's
Voltage Controlled Divider:
http://www.cgs.synth.net/
A half-wave rectifier will simply cut off the negative voltages, but
allow all positive voltages to pass through with as much accuracy as the
resistors in the circuit allow.  The rectifier circuit uses one TL072 op
amp (both sections).  A full-wave version is also doable with one dual
op amp.  The full-wave will invert any negative voltages and make them
positive.  Use whichever circuit meets the need.  See Electronotes for
FW rectifier circuits.
-Richard Brewster
>voltages only?
>Thanks, Jeff
>Yahoo! Groups Links
