If you are into quantizing, get the Scale Quantizer. I probably use the
quantizer capability of the Miniwave more than anything else, both bank
15 of the original ROM and the Scale Quantizer. It's a trade-off,
because the Miniwave can be used either as a quantizer or as a waveform
transformer, but not both at once. Depends on what you want to do. Two
ROMs is not enough! If you've got the expansion board, your problem is
to decide which *ten* ROMs to use. Since there are barely that many
available right now, it's not a big problem.
-Richard
mate_stubb wrote:
>By far the most fun for me is the Scale Quantizer from Matthew Davidson.
>Moe
>--- In motm@yahoogroups.com, "djbrow54" <davebr@e...> wrote:
>>Is there a consensus for what the next rom or roms should be for the
>>miniwave beyond the standard default rom? What do people recommend?
>>I've got the expansion board and need to start populating it.
>>Dave
