MOTM
Using Velocity
Using Velocity
2005-02-21 by Jeff Laity
How do I use velocity to control a VCA? What I would like to do is have
the velocity CV from my MIDI/CV converter control the amount that the
envelope affects the VCA. I need some sort of VCA between the envelope
out CV and the VCA CV in. I tried using the first half of the 190, but
that didn't work so well. Do I need a DC VCA? I glanced through the
MOTM modules, but I didn't see any that mention this application.
Re: [motm] Using Velocity
2005-02-21 by Paul Schreiber
You need the "lower" VCA of the '190, that one is DC coupled.
Paul S.
To: "'MOTM List'" <motm@yahoogroups.com>
Sent: Monday, February 21, 2005 4:17 PM
Subject: [motm] Using Velocity
2005-02-22 by imorpheusl@aol.com
You could use 2 VCAs in series - the first with an envelope generator
attached to it's CV in and the second with a CV velocity signal going into its  CV
in (thekenton pro2000 midi-cv convertor for example allows you to output
velocity as CV from one of its 6 aux outs). Then just pass the audio through VCA  1
audio in, to VCA out, then into VCA 2 audio in, to VCA out into your mixer or
 whatever.
-Chaz
2005-02-22 by Jeff Laity
Is this also the method for varying the amount that an LFO controls VCO
vibrato?
>  Paul S.
>  ----- Original Message -----
>  From: "Jeff Laity" <synthetic@...>
> have
> the
> envelope
> but
2005-02-22 by john mahoney
> envelope generator attached to it's CV in and the
> second with a CV velocity signal going into its CV in ...
My understanding is that you'll get less noise by using the EG-driven VCA last. When the envelope is "off" its VCA will cut off *all* the sound, including that of the velocity VCA. But maybe the MOTM VCA is quiet enough that it doesn't matter.
john
Re: Using Velocity
2005-02-22 by tontaub
You also could use a stooged Oakley Multimix summing up all the CVs
and feed the resulting CV into the VCA.
That made it even more versatile since you could invert the CVs.
  Michael. (who thinks that MOTM VCAs are dead quiet ;-)
> john
LFO mod of VCO (was Using Velocity)
2005-02-22 by Dino Leone
I've been thinking about the same issue and I'm
wondering whether it's necessary to "waste" a VCA just
to attenuate the CV of the MOTM380 LFO to feed into
the FM of a MOTM300...
right now I keep the FM attenuator on the MOTM300
always between 0 and 1 (on a full scale of 0-10)... so
I was thinking if it would make sense to modify a
MOTM380 so that its output amplitude is smaller? Or
maybe I'm just missing something here again?
Best,
Dino
> an LFO controls VCO
> vibrato?
> DC coupled.
> >  Paul S.
> would like to do is
> > have
> > the
> VCA between the
> > envelope
> > but
> glanced through the
> this application.
Do you Yahoo!?
The all-new My Yahoo! - Get yours free!
http://my.yahoo.com
Re: LFO mod of VCO (was Using Velocity)
2005-02-23 by tontaub
If it's just attenuation without any time dependency you virtually can
do that whereever you want (mostly depending on the rest of the
patch). If you want to control that remotely from a let's say MIDI
keyboard you will need a VCA which is controlled by the MIDI-CV interface.
However - no one stops you to grab the knobs of your modular when
playing ;-)
Did this answer your question?
   Michael.
> Best,
> Dino
> > an LFO controls VCO
> > vibrato?
> > DC coupled.
> > >  Paul S.
> > >  From: "Jeff Laity" <synthetic@e...>
> > would like to do is
> > > have
> > > the
> > VCA between the
> > > envelope
> > > but
> > glanced through the
> > this application.
> Do you Yahoo!?
> http://my.yahoo.com
Re: [motm] Re: LFO mod of VCO (was Using Velocity)
2005-02-23 by Dino Leone
Thanks so much! It does indeed answer my question. I
also got a very good answer from Larry (shown below).
It seems I probably need both solutions - a simple
attenuation (read: home-made panel with a bunch of
pots)  and maybe some additional VCAs..
Thanks again,
Dino
J. Larry Hendry wrote:
I would not modify the output of my 380.  You have
better options.  If
you
are just using the VCA as a static attenuator (i.e. no
voltage control
of
the modulation amount) you have two other good
options.
1.  You can change one resistor in the MOTM-300 which
will change the
gain
of the FM circuit.  So, the of 0-10 could be the
equivalent of say 0-5
or
even less.
2. You could use a mixer to attenuate the sound. Or a
reversing
attenuator
(like the Oakley multimix)
3.  You could build a simple passive attenuator for
this made from a
single
pot and 2 jacks.
Larry
> you virtually can
> rest of the
> let's say MIDI
> modular when
> playing ;-)
>    Michael.
> just
> into
> 0-10)... so
> Or
> > Best,
> > Dino
> that
> > > an LFO controls VCO
> > > vibrato?
> is
> > > DC coupled.
> > > >  Paul S.
> What I
> > > would like to do is
> > > > have
> > > > the
> of
> > > VCA between the
> > > > envelope
> > > > but
> VCA? I
> > > glanced through the
> mention
> > > this application.
> > Do you Yahoo!?
> > http://my.yahoo.com
> Has someone you know been affected by illness or
> disease?
> Network for Good is THE place to support health
> awareness efforts!
http://us.click.yahoo.com/pKxVKC/UOnJAA/n1hLAA/VpLolB/TM
>     motm-unsubscribe@yahoogroups.com
Do you Yahoo!?
Yahoo! Mail - Helps protect you from nasty viruses.
http://promotions.yahoo.com/new_mail
2005-02-23 by Jeff Laity
I should have been more specific – I want to use the mod wheel to
control LFO "depth" for vibrato. I'll use the pitch wheel for pitch
changes and the mod wheel for vibrato for a lead sound, for example. I
need a VCA for this, correct? The mod wheel CV goes to the CV in of the
VCA, LFO goes to the VCA in, VCA out to VCO FM input. I can only use
channel 2 of the 190, because this channel is DC coupled. Do I have
this right? Is there another way to do this? I'm still trying to figure
out how to do functions that I take for granted on preset synths.
>  Thanks again,
>  Dino
>  better options.  If
>  you
>  voltage control
>  of
>  options.
>  will change the
>  gain
>  or
>  even less.
>  reversing
>  attenuator
>  this made from a
>  single
>  pot and 2 jacks.
>  Larry
>  > you virtually can
>  > rest of the
>  > let's say MIDI
>  > modular when
>  > playing ;-)
>  >    Michael.
>  > just
>  > into
>  > 0-10)... so
>  > Or
>  > > Best,
>  > > Dino
>  > that
>  > > > an LFO controls VCO
>  > > > vibrato?
>  > is
>  > > > DC coupled.
>  > > > >  Paul S.
>  > What I
>  > > > would like to do is
>  > > > > have
>  > > > > the
>  > of
>  > > > VCA between the
>  > > > > envelope
>  > > > > but
>  > VCA? I
>  > > > glanced through the
>  > mention
>  > > > this application.
... one never can have too many VCAs  ;-)
I'd consider an Oakley Multimix anyway.
As Larry stated it's an reversing attenuator.
And with the change of some resistors you also can achieve an
amplification which gives a range of let's say of a factor from -2 ...
+2 if you want. It's a quite versatile module in 1U.
HTH, Michael.
HTH, Michael.
> I need a VCA for this, correct?
Yes.
Yes.
> I can only use
> this right?
Yes.
Not to my knowledge.
Whenever you want to change the level of a signal you need an
attenuator and/or amplifier. Both CV controllable. That is a VCA.
The only thing you've to take into account is wether the signal has to
be DC coupled or not. That can become quite complex. But take your time.
Regardless if the synth is digital or analouge or whatever ;-) , it's
basically doing the same thing.
You're on the right track!
  Have fun, :-) Michael.
2005-02-24 by cormallen
If you haven't already got a MIDI-CV converter, can I recommend the
Kenton Pro-2000?  That provides a couple of (digital) LFOs internally,
the amplitude of which can be controlled by MIDI controllers or
aftertouch or whatever.   The LFO output can then be added internally
to the CV output (together with pitch wheel info), so that you don't
need a mixer/LFO/whatever else...
Obviously the MOTM modules can handle everything you could want, but I
find myself using the Kenton internal stuff by default for pitch bend
and vibrato.   It's cheap and it leaves my modules free for handling
the more outrageous stuff.
(It does a reasonable portmento too, though there I prefer to use the
MOTM for it because of the CV'able up/down times).
Harry
