MOTM
Re: Using Drum Triggers
2005-06-07 by paulhaneberg
I too have a V-Drum set.  I hadn't thought about using it to trigger
the modular directly, but it seems like an idea with possibilities.
The biggest problem is with false triggering.  I think the simplest
way to address this problem is for you to have a circuit that
compares every impulse on all the pads and initiates a trigger for
the pad with the largest impulse.  The difficulty here is that you
could hit more than one pad at a time, or more than two if you use
your feet.
You also need to have a delay time between triggers for each pad to
prevent multiple triggers from just one hit.
A sensitivity control could either control the amplified gain of the
signal prior to triggering, or could actually set the level required
to generate a trigger with a comparator.
I don't think noise is too much of a problem, but hitting anywhere
on the kit, including the stand can potentially generate an unwanted
impulse.  Even an overenthusiastic fellow band member can generate a
false trigger by jumping around.
It's a difficult problem, that I've never seen solved entirely to my
satisfaction.  I use my kit for recording only, and I always edit
the midi stream, so I'm very aware of all the false triggering that
does occur.
Paul Haneberg
Re: [motm] Re: Using Drum Triggers
2005-06-07 by imorpheusl@aol.com
Would it be possible to use a gate to filter out triggers below a certain level? Would this work? I work at Guitar Center in Boston and I actually was asking the drum department people about v-drum pads and how they work exactly last week. I was thinking about buying some for my modular to trigger EGs.
-Chaz
PS: if you need new gear email me I would love to help out and hook up fellow motm'ers :P
To: motm@yahoogroups.com
Sent: Tue, 07 Jun 2005 18:03:27 -0000
Subject: [motm] Re: Using Drum Triggers
your feet.
does occur.
Paul Haneberg
Yahoo! Groups Links
2005-06-08 by Greg Amann
V-Drum triggers are alittle different than the garden variety piezo technology of the past. They are "stereo". Well they use a stereo cable anyways. What that's aboot is that it allows the pad and the "brain" to differentiate between a pad centre hit and a rimshot. I have not thrown my V-Drums on my 'scope since I can't capture events (at least I don't think I can). Anyone interested in the minutae of V-Drum pads can contact me off list (I do not claim to be an expert). I think a discussion of triggering MOTM with V-Drum pads belongs on this list; I think the nuts and bolts of V-Drum technology probably does not so I will shut up. :-)
PLL, BFG
-Chaz
your feet.
does occur.
Paul Haneberg
------------------------ Yahoo! Groups Sponsor --------------------~-->
Has someone you know been affected by illness or disease?
Network for Good is THE place to support health awareness efforts!
http://us.click.yahoo.com/pKxVKC/UOnJAA/n1hLAA/VpLolB/TM">Click
Here!
Yahoo! Groups Links
<*> To visit your group on the web, go to:
    http://groups.yahoo.com/group/motm/
<*> To unsubscribe from this group, send an email to:
    motm-unsubscribe@yahoogroups.com
<*> Your use of Yahoo! Groups is subject to:
    http://docs.yahoo.com/info/terms/
2005-06-08 by Neil Bradley
> -Chaz
> fellow motm'ers :P
Thanks kindly for the offer! ;-)
I have a TDW-10 VStudio setup and the triggers don't trigger anything. From what
I understand, they're like guitar pickups - they need some sort of voltage going
through them to detect their movement.
-->Neil
