MOTM
Decay (and not the dental kind)
2005-06-24 by Matthew Hiscock
Hi all,
I had a pretty basic "theory" question about how decay works in a
(mono) modular:
Let's say I have a simple [keyboard -> vco -> vcf -> vca -> mixing
desk] setup, and that I'm using an eg to control the vca.
When I press a key on the keyboard, it triggers a certain note on the
vco and also makes the eg fire. Then when I take my finger off the
keyboard, does that note instantly stop sounding at the vco level? I'd
be inclined to think "yes" but then what about decay....
If I take my finger off the keyboard, the eg wants to have the signal
continue - if there's no more signal, obviously the "decay" control is
irrelevant.
Is it then the case that the vco in a modular is *always on* so that
you *need* a vca to just selectively bring up the volume when a note is
actually being played? And the purpose of voltage control is to just
adjust the frequency, not turn the signal "on" or "off"?
I ask this because I'll be growing my modular (from just a filtering
station) in very slow increments, so I want to make sure I get the
order right.
thanks,
Matthew
_________________________________________________
+ Reviews for Xpander/365Mag: www.365mag.com +
+ and Exclaim magazine: www.exclaim.ca +
+ The Bootleg Sounds label: www.bootlegsounds.com +
Re: Decay (and not the dental kind)
2005-06-24 by coyoteous
--- In motm@yahoogroups.com, Matthew Hiscock <audio@b...> wrote:
> Hi all,
> (mono) modular:
No and I think "release" is the proper term for decay here.
> irrelevant.
Yes, if you're talking about release.
Yes, always on.
> order right.
> thanks,
> Matthew
Barry
Re: [motm] Decay (and not the dental kind)
2005-06-24 by Greg Amann
I think you have a minor misconception aboot the VCO.  The keyboard does
not cause the VCO to trigger or fire.  The  VCO is always "on", the
keyboard (in your configuration) is telling the VCO what frequency to
generate.  If you remove the ADSR and the VCA from the patch, you will
see that the VCO is always on and that the frequency depends on the last
keyboard note played.
The keyboard is sending oot two signals in your patch: 1 is the CV to
the VCO to determine the pitch of the note and 2 is the gate to the ADSR
to determine the dynamic envelope.
Does this help?
PLL, BFG
Matthew Hiscock wrote:
> Hi all,
> (mono) modular:
> irrelevant.
> is actually being played? And the purpose of voltage control is to
> just adjust the frequency, not turn the signal "on" or "off"?
> order right.
> thanks,
> Matthew
> + Reviews for *Xpander/365Mag*: www.365mag.com +
> + and *Exclaim* magazine: www.exclaim.ca +
> + The *Bootleg Sounds* label: www.bootlegsounds.com +
Release yourself WAS Decay (and not the dental kind)
Ah yes, you're right. Silly error. I guess the above would be a better
title.... well, more accurate anyways.
Either way, thanks Barry and Greg for the help.
Matthew
>> Hi all,
>> (mono) modular:
>> irrelevant.
>> is
> Yes, always on.
>> order right.
>> thanks,
>> Matthew
> Barry
