MOTM
Swapping Power Supplies
2005-08-25 by Chris //
I am thinking big and would like to order a 1.5 amp power one linear supply HBB15-1.5-A or a 3 amp HCC15-3-A (i know this one is a bit bigger)...
Can I just take out the supply from the MOTM-900 and replace it with one of the above, will that work??? Does the fuse need to be changed in the plug????
Thanks
Re: [motm] Swapping Power Supplies
2005-08-25 by synth1@airmail.net
> bigger)...
> plug????
Just the fuse. The fuse rating you need is printed on the side of the
power supply. I use standard 5mm X 20mm fuses, "Slo-Blo" type from Bussman
or Littelfuse.
Paul S.
2005-08-25 by Greg Amann
The 800 mA Power One supply that comes in the MOTM-900 is a different size (namely, smaller) than the HBB15-1.5A. Check oot either the Power One site or DigiKey: both list the dimensions of the supplies. The larger supplies will not be "screw compatible" with the 3U '900 mounting panel.
PLL, BFG
> bigger)...
> plug????
or Littelfuse.
Paul S.
RE: [motm] Swapping Power Supplies
2005-08-25 by J. Larry Hendry
The 19" 2U high rack panels (if you are rack mounting) I sell for power supplies will hold larger supplies. I have some of them not drilled for 900 for just such occasions.
Larry H
From: motm@yahoogroups.com [mailto:motm@yahoogroups.com]On Behalf Of Greg Amann
Sent: Thursday, August 25, 2005 3:38 PM
Cc: Chris //; motm@yahoogroups.com
Subject: Re: [motm] Swapping Power Supplies
PLL, BFG
> bigger)...
> plug????
or Littelfuse.
Paul S.
2005-08-26 by Richard Brewster
Depending on your cabinet, you may be able to mount the larger supply
near to the MOTM-900 panel.  You may be able to reuse the original AC
wiring from the panel to the new supply.  And you can move the
12-connector distribution board from the MOTM0-900 panel and locate it
in a more convenient spot.  I use dot com cabinets and mount the MOTM
power supply panels on the back with the supply chassis fastened down to
the wood just in front of the panel.  I mount it length-wise to make
more clearance for modules in front of it.
-Richard Brewster
> mounting panel.
> PLL, BFG
>> > bigger)...
>> with one
>> > plug????
>> Bussman
>> or Littelfuse.
>> Paul S.
2005-08-26 by Oakley Sound
Personally I would always go for two smaller power supplies than one big
one. I know size may be an issue, but there are advantages to a
distributed system of smaller supplies.
Firstly, if your power supply dies, there is less chance of every module
being affected. This is unlikely with a Power One, but things do go
wrong.
Secondly, a higher rated supply, say 3A, will be quite happy to drive 3A
into your whole system or just one module. So if you have one faulty
module it will quite happily chuck 3A into it and possibly burn something
out.
Thirdly, you can more likely ensure that the +15V and -15V lines stay at
that level if the power busses are shorter. Which they would be with a
smaller system of multiple busses each driven from their own supply,
compared to one large distributed buss driven from one supply. Also any
noisy modules that you may have can get their own supply leaving the
audio pathway to have a nice clean supply for itself.
Fourthly, Power One supplies do latch up with less than their maximum
rated load. This is a flaw with their design whereby one supply line
powers up before the first so the other one switches off. I have a sneaky
feeling that using two smaller supplies will actually get you more module
count than one bigger one.
In a nutshell it is probably better to use two MOTM supplies not one
bigger one.
Tony
2005-08-26 by Chris //
Hello
Thanks everyone for the supplies, I will put a little thought into this and how it will work best with my setup and than decide which route to go....
Also for buying extra MOTM-900 PCB's, is it as easy as wiring additional boards to the power supply like the initial board.
thanks
Sent: Thursday, August 25, 2005 2:41 PM
> bigger)...
> plug????
or Littelfuse.
Paul S.
one more question, if i was to buy a bigger power supply and mount it in my wood cabinet and mount my momt-900 to the side of a wood cabinet, will i have ground issues because it is not attached to a metal frame...
sorry i know nothing about this and dont understand anything about it either.
Sent: Friday, August 26, 2005 8:04 AM
Hello
thanks
> bigger)...
> plug????
or Littelfuse.
Paul S.
2005-08-26 by Paul Schreiber
No, but for best results mount them next to each other (not on opposite ends of the cabinet). You will need 1 large gauge (say #10)
ground wire to connect the output grounds together.
Stooge Larry is can also advise.
Paul S.
Sent: Friday, August 26, 2005 8:13 AM
Hello
thanks
> bigger)...
> plug????
or Littelfuse.
Paul S.
2005-08-26 by Robert van der Kamp
> large gauge (say #10) ground wire to connect the output
> grounds together.
Okay, but what to do when you have two cabinets, each with
their own '9xx PSU to feed the modules in the cabinet? Do
they need the above treatment too?
- Robert (hoping to build cabinet #2 soon)
No. No different from plugging a synth into a mixer into a power amp.
The cables carry the ground.
Paul S.
To: "MOTM List" <motm@yahoogroups.com>
Sent: Friday, August 26, 2005 8:33 AM
>> grounds together.
2005-08-26 by Adam Schabtach
I've seen this happen in my system. I started with a pretty hefty Power-One
supply and paid careful attention to the total calculated current draw as I
added modules. Eventually the supply would not turn on reliably, even though
the total current draw was far less than its rated limit. It may or may not
have been coincidental that one of the last modules I added was a Blacet
Time Machine, a module that has an asymmetric current draw (i.e., it draws
more from the +15V supply than the -15V side). The system would run once it
powered up, but it didn't always power up on the first attempt which was
disconcerting.
I added a second, smaller Power One supply, redistributed the modules across
the two, and now both supplies power up without trouble.
--Adam
(received his third supply yesterday)
www.studionebula.com
