MOTM
New MOTM-650 firmware uploaded
2006-07-22 by Paul Schreiber
www.synthtech.com/m650/motm650rc2.sfi
This new firmware address the following issues:
* Bugfix - Arpeggiated notes now play in sync w/ Beat LED with 1X clock
  divisor for all clock sources.  NOTE: arpeggiator will now reset
  clock to start with first keypress only if set to internal clock sync
  with midi clock transmit turned off.  All other modes wait until next
  clock is received to play the note.
* Bugfix - Eliminated lockups when changing arpeggiator clock source or
  Midi clock transmit options.
* Bugfix - Selecting midi clock transmit sends start command.
* Bugfix - Playing the arpeggiator no longer plays lowest note (0).  As
  part of same bugfix, it no longer requires 2 or more notes to be held to
  start arpeggiator.
* Bugfix - Tuning Tables 8-16 now load and play correctly.
Please download this and let me know if there are any other issues that need to
be address (besides adding the Hz/Volt table).
Paul S.
