MOTM
motm panel sizes
motm panel sizes
2006-08-29 by Jason Proctor
hey can someone point me to the "official" panel sizes and mounting
hole locations etc MOTM modules?
thanks guys
Re: [motm] motm panel sizes
2006-08-29 by Scott K Warren
http://www.synthtech.com/motmfaq.html#Q8
> thanks guys
oh right thanks -- and the inset for the mounting holes?
Whoops, I was too fast.
That FAQ entry doesn't say where the mounting holes are. Paul S
probably needs to settle this, but according to the Front Panel
Designer files I've collected from the web, the mounting holes are
inset 0.2500 inch horizontally and vertically from the corners. But
the 0.015 inch "slop gap" has me wondering... Anyway if #8 mounting
holes are drilled as I said, the panels fit on Paul's rails just fine.
skw
2006-08-29 by Paul Schreiber
try
www.synthtech.com/tech
there should be a PDF of the MOTM-440 panel that has all the relavant
dimensions.
Paul S.
ok that clears it up. thanks. FPE is too expensive to get it wrong :-)
>try
>dimensions.
>Paul S.
>Yahoo! Groups Links
