MOTM
DotCom DooHickey (+5V)
2006-09-01 by pow333us
Is it possible to use a traditional 3 rail MOTM power supply and then
hook up this synth.com QMPSA dongle to generate the necessary +5 volts
for an MOTM 650? It seems reasonable. Has anyone tried? Is there a
reason why not?
Re: [motm] DotCom DooHickey (+5V)
2006-09-01 by Dave Bradley
I d be leery that the little 3 terminal regulator would not be able to provide enough current for the display. Haven t done any checking though. Moe ... --
Re: DotCom DooHickey (+5V)
2006-09-03 by phantom_of_the_oscillator
I don't think that the DotCom DooHickey, aka the QMPSA - MOTM/Blacet
Power Supply Adapter, Will work for the MOTM-650.  At the bottom of
the MOTM-650 page it says "NOTE: This module requires a MOTM-950 or
other source of +5V, 575ma power"  and the DotCom site lists a +5V
output of only 200ma max for the DooHickey.  You would be 375ma short
of the needed current.  Remember, powerful modules like the 650
require, well, power.
JVG
--- In motm@yahoogroups.com, "Dave Bradley" <mate.stubb@...> wrote:
> I'd be leery that the little 3 terminal regulator would not be able to
> provide enough current for the display. Haven't done any checking
though.
> Moe
> > reason why not?
> > Yahoo! Groups Links
> Dave Bradley
