Pot Chiclets
2006-09-02 by John Loffink
While everyone is waiting for their MOTM kits to arrive, here's a bit of shameless self promotion. Pot Chiclets are an aid for assembly of MOTM kits, DIY kits and module conversions using Spectrol or Bourns pots. Instead of painstaking J lead preparation, pots are mounted to the Pot Chiclet mini PC board, and the wires are soldered to the provided PC board holes. These are useful for almost any MOTM 2U wide panel that uses Spectrol pots as the second row of pots do not mount to the main module PCB. Pot Chiclets allow you to mount the pot to a (mini)-PCB as was intended, then solder wires between pads on the main board and pads on the Pot Chiclet. http://www.wavemakers-synth.com/motm/chiclets.html These are available for shipping. I also have a limited number of old style Pot Chiclets (6 holes/pads), available at a discount, that will work fine with MOTM kits - inquire. John Loffink The Microtonal Synthesis Web Site http://www.microtonal-synthesis.com The Wavemakers Synthesizer Web Site http://www.wavemakers-synth.com
