MOTM
Celebration and trouble
2006-10-14 by shari_en_jin
YAY!!!! I just finished my first module, a 390 dual LFO!!!!
Most everything works find and dandy, however, on LFO-A, the Triangle(Tri-A) works great,
but the Square(SQR-A) gives such a low output it barely even modulates(in my trial run) the
frequency of the oscillator.   The same thing with B LFO, but its the Triangle(TRI) output that
gives little output, but the SINE and SQR seem to work fine.
Any of you more experienced guys or girls out there have any quick ideas of why? before I
start dismanteling the poor guy and loose some hair trying to figure out whats goin on?
Muchas Garcias,
Ti_
Re: [motm] Celebration and trouble
2006-10-14 by Paul Schreiber
With power off, get a DVM and measure the resistance between tip and sleeve
(signal out and ground). Use a patchcord plugged into the jack, take DVM leads
and be SURE your hands are not touching the probes, make the measurement.
Sometimes new folks overheat the coax, shorting the outputs.
Paul S.
To: <motm@yahoogroups.com>
Sent: Friday, October 13, 2006 8:44 PM
Subject: [motm] Celebration and trouble
> works great,
> trial run) the
> why? before I
> goin on?
> Muchas Garcias,
> Ti_
2006-10-14 by timothy cooper
AHHHHHAAA! yes, that seems to be the problema!  So
that basically means that I heated up the coax cable
so hot it just melted the sleeve of the inner wire
exposing it to the braid/ground right?  I really need
to get a different tip for my iron, the one that came
with my WTCPT is a little tough to get into some of
the spots, and RReally tough trying to leave any room
on some the pads on the board for the solder to flow
onto.  So, thank God I didn't fry one of the chips or
caps!  All in all I think I did a fairly decent job,
aside from toasting the coaxial leads, for a first
try! Well, kind of, I put together a PAIA theremax a
while back and OMG what a difference! the MOTM circuit
boards are really Really nice, although it took a few
solders to get used to dealing with those microscopic
pads!(compared to the PAIA boards) Anyhow, if I have
time tomorrow I'll try and track down some replacement
cable and one of those fine point screwdriver tips!
Thank you SOO  much for interupting a fine Friday
evening to toss out that little tid bit of info!
Ti_
> outputs.
> Paul S.
> From: "shari_en_jin" <shari_en_jin@...>
> dual LFO!!!!
> > works great,
> > trial run) the
> B LFO, but its the
> work fine.
> > why? before I
> > goin on?
> > Muchas Garcias,
> > Ti_
> > Yahoo! Groups Links
Do You Yahoo!?
http://mail.yahoo.com
