MOTM
More Quantizer thoughts
2007-08-26 by Paul Schreiber
a) I can always make it 3U wide but it will be more $$ (say from $299 to
$359, still less than others out there).
b) I can make it dual with more features. So maybe it's a dual (2U) versus
quad  (3U) issue. One advantage of the 3U wide is I can use the same
encoder/display scheme as the Cloud Expander (6 programmable parameters at
once in the display).
c) I understand that people change the scale via CV all the time. But, and
this is an important thing to consider, is it changed *precisely*? Or do
people "just want it to change" every so often, and not care *exactly* what
scale is used, just to it's "not the last one".
Because this implies 2 things:
1 - the scales are in the 'correct' order
2 - you are somehow feeding a "target voltage" in there and picking out the
*exact* scale of interest
What I will bet is that people just want some sort of *change*, that moving
*specifically* from ScaleA to ScaleB is not the intent, but rather "boy this
sounds neat if I have change to a different scal ever so often". The reason
I bring this up is how the HW/SW is implemented. If you are implying that "I
like to *sweep* through" a certain MiniWave bank/set of scales, saw with a
sawtooth LFO or whatnot, that is very different than "just hop over to
something different".
The other implication is being able to have a "scale librarian" (why I
prefer the USB model) because then you can re-order the scales/banks around
to your liking. You *need this* in order to 'sweep through' a scale set in a
given sequence. Otherwise you are at the mercy of how the scale ordering is
done at the outset.
Many people like this MiniWave feature, but I suspect they just "throw" CVs
at it an see what comes out :)
Paul S.
Re: [motm] More Quantizer thoughts
2007-08-26 by loopcycle
> Paul S.
Yez, correct  :)
screw the RIAA.  artists, take control.
share and remix music, legally, on your own terms.
http://ccmixter.org
Need a vacation? Get great deals
to amazing places on Yahoo! Travel.
http://travel.yahoo.com/
2007-08-26 by Scott Juskiw
I use both methods. Sometimes the scales just happen to be ordered in
a bank in a musically useful pattern and simply sweeping through them
with a slow triangle wave works fine. Other times I pick out a few
specific scales that are not "right next to each other" in the bank
and have to send specific voltages to select those scales. It takes a
few more modules to wire that up, but it's not difficult.
I suppose if you wanted to get really fancy you could offer a
"program" mode where users could select which scales they want to
stick into different voltage slots. Then they could sweep through
that custom bank with a triangle LFO. Sort of like programming songs
into your CD player.
I like your idea of being able to create custom scales and banks with
a "scale librarian". That would probably eliminate the need for a
"program" mode, but would require more work for the user (hooking up
a computer to the module just to reorder a few scales would be a
hassle).
2007-08-27 by Mark
On 8/26/07, Paul Schreiber put forth:
I would say most people would want to change it to something specific.
That's not necessarily true.  For example, while I rarely ever used
my MiniWave to quantize CV's, I often use it process audio.  Imho,
sweeping through the banks is uselessly chaotic.  Then again, the two
ROMS that I have installed in mine vary greatly from bank to bank.
However, sometimes I do switch from one specific bank to another.  In
that case, by using the bank offset and CV scaling, I can use a gate
or pulse LFO.  Alternately, one could use a comparator, MOTM-700,
etc.  If you wanted to use an EG or LFO for more than two exact
results, you can also use a quantizer to control another quantizer :)
>done at the outset.
That isn't true if you are using a step sequencer, or CC's with
MIDI-to-CV converter -- the internal order of the scales doesn't
matter as you can externally sequence reasonably precise voltages in
any order.
While I often I sweep the waves with an EG or LFO to hear what
happens, I can then adjust the modulation source (320, 800, etc.) and
the offset and scaling on the MIniWave itself to get what I want.
