FW: [motm] Quad Quantizer: need your inputs
2007-08-26 by Tkacs, Ken
A quantizer AND ASR in one unit? This could be my favorite module of the past five years. (Then I'll be pining for a pitch-to-voltage converter...) I much prefer USB over MIDI for programming, personally. ________________________________
From: motm@yahoogroups.com on behalf of Paul Schreiber
Sent: Sun 8/26/2007 11:21 AM
To: MOTM List
Subject: [motm] Quad Quantizer: need your inputs
A "fallout" of designing the expansion module for the Cloud Generator is a
nice 4ch (quad) quantizer in a 2U wide panel.
The UI is a 16ch x 2 line LCD with 4 rotary encoders. These select the scale
for each channel. LCD displays the scale name. For a relatively small price,
I can add a USB port to allow downloading of your own scales (as long as I
have people willing to write the host app).
I could aso have 4 pots for transposing the scale (say in 1 semitone steps).
And, there could be a "cascaded S&H mode" where there is a clock (int or
ext) to sample input #1, next pulse #1 is copied to #2, etc ("analog shift
register"). Maybe that UI is a 3-position toggle with:
QUANTIZE
SH NORM
SH SHIFT
Normal is 4 independent S&H channels (sharing the common clock).
I suppose one could go "nuts" and make a super-PSIM whiz-bang but maybe that
is later down the road. I want something with less than 1 man-year of SW
development :)
So, show me you panel mockups/feature list. The LCD is 80mm lond and 35mm
wide. There are 2 encoders on the top and 2 on the bottom.
Paul S.
Yahoo! Groups Links
