MOTM
Blacet/Wiard 2090 Mini Wave
2008-02-11 by nootie1000
Has anyone had any experience with the Blacet/Wiard 2090 Mini Wave?
Is it worth converting it to MOTM-format,if yes, where do i get the
frontpanels,brackets and so on?
And what about the commercial ROM's,are they still available,and who
sells them?
PS (just read about the MOTM-maxiwave!!!)
RE: [motm] Blacet/Wiard 2090 Mini Wave
2008-02-11 by Dave Bradley
Heh.
The MiniWave was the single most popular Stooge panel ever made. I
believe there were at least 4 designs before it was all done.
It was hotrodded with extra rom boards and voltage controlled rom selection.
Look here:
http://www.tellun.com/motm/diy/jlh2090cv/JLH-2090CV.html
I don't know if parts are currently available.
Moe
On 2/11/08, nootie1000 <Remi.Van.Bulck@...> wrote:
> Hi,
> sells them?
Dave Bradley
Dave Bradley
Re: [motm] Blacet/Wiard 2090 Mini Wave
2008-02-11 by Mark
On 2/11/08, nootie1000 put forth:
>Hi,
Yes, it's awesome.  It's not the easiest thing to build, although I
did reduce the number of wires by using ribbon cable for the LEDS.
You should also check out the instructions and mods on Larry's page.
I strongly recommend the EG mod.
It's definitely worth it if you can get the panel and bracket.  While
I'm fairly sure you can get the bracket from Scott Deyo, I do not
know if he sells the panel.
http://www.bridechamber.com/
>sells them?
I have no idea, but if you google and find out that they are no
longer available I wouldn't let that deter you.  Mine only has the
two ROM's that Blacet sold, and it's a very useful and versatile
module.
Re: Blacet/Wiard 2090 Mini Wave
2008-02-25 by leitner6
There's also the Modcan series-B blacet/wiard mini-wave which is
already in MOTM format.  The I/O is setup for lower voltage range. (+/-
5v) Personally I don't find that a big deal.
-Larry
--- In motm@yahoogroups.com, "nootie1000" <Remi.Van.Bulck@...> wrote:
> Hi,
> sells them?
[motm] Re: Blacet/Wiard 2090 Mini Wave
2008-02-25 by Jason Proctor
yes, the Modcan one includes a driver oscillator, too -- and the
module is really expensive ($549).
unfortunately Blacet no longer sells the basic (ie format neutral)
kits, so it's necessary to buy a Frac kit ($189). Schaeffer in
Germany (aka Front Panel Express in the US) can make a panel
(probably $50ish), and Bridechamber sells suitable brackets (cheap).
then you can either reuse the Frac pots somehow or get some
Alpha/Bourns/Spectrol etc, and Alcoswitch knobs or equivalent. MOTM
can supply those IIRC.
sounds like hassle, but the Miniwave is worth it. i have an MOTM
format one, i love it to death, and i'm going to have another when my
life permits it.
hth
>-Larry
2008-02-25 by Mark
On 2/25/08, leitner6 put forth:
>5v)
Not only that, but it's white.  So it's more like the photo-negative
of MOTM format :)
On 2/25/08, Jason Proctor put forth:
I agree it's unfortunate.  Not only is there MOTM format, there is
also eurorack, dotcom, etc.  Which means that anyone else buying a
frac kit would not only wind up with a panel they don't need, but
possibly pots and jacks as well.  That seems like a waste.
