MOTM
MOTM-520 Cloud Generator additional demos
2008-02-25 by Paul Schreiber
>I have added 3 new MOTM-520 Cloud Generator demos that use the Phase Offset
>registers (the last bit of FPGA code needed to basically complete the audio
>portion of the feature set).
> They (and all the others if you have not heard them) are located here:
> www.synthtech.com/m520
> the 3 new files are cg_phase_1, cg_phase_2 and cg_phase-synced
> These are short snippets showing manual Phase Offset (via twisting panel
> knob), using sawtooths waves (all 16 of them) set to random initial phase,
> random phase + some frequency spread, and in-phase (respectively).
> The hardware design is undergoing final design review this month before I
> start pcb layout and final beta testing before production runs. Since
> there are 2 sets of firmware (ARM CPU and Xilinx FPGA) we want to be sure
> it is tested to minimize the need for a bug fix (the code is field
> upgradeable, but not without some 'hassle').
> Paul Schreiber
> Synthesis Technology
