MOTM
TB-303 with MOTM...
TB-303 with MOTM...
2008-07-23 by earthtodylan2000
Hello,
 My fiend is going to loan me his TB-303 for an extended time period. I was wondering if
anyone had any tips about how to use it with an MOTM system.
 I do understand that I can use the CV out and CV gate to add additional voices/VCO's to mix
with the 303.
 What I want to do is actually clock the 303 to a sequencer or vice versa.
 I'm new to this sort of synthesizing and not hip to DIN inserts.
Dave
Re: [motm] TB-303 with MOTM...
2008-07-23 by Mark
I have a couple of TB-303's.  It uses Roland Sync24, commonly known
as DIN sync, which is 24ppqn.  It has sync in, but not sync out, so
it cannot be used as a master (unless you put the cable in half-way
which is mechanically unreliable).  So you need something that can
generate both DIN sync and a sequencer clock.  In my set-up that
would either be a Kenton Pro-4 synced to MIDI F8, or a TR-808 with
one of the trigger outputs programmed as a sequencer clock.  There
are a number of other devices that generate both DIN sync and clock
pulses.  If you don't care about being able to slave to MIDI, the
least expensive option is probably a TR-707, which sells for around
$100 (it has MIDI out but not MIDI in).
On 7/23/08, earthtodylan2000 put forth:
>Hello,
>with the 303.
>Thanks,
>Dave
2008-07-23 by loopcycle
a mobius is an excellent timing/clock centerpiece.  shame its discontinued.
a funny thing has happened to the 707 just lately.  in the last six months or so, the average going price has jumped to $250-300!
--- On Wed, 7/23/08, Mark <yahoogroups@...> wrote:
>  There
> and clock
> MIDI, the
> for around
2008-07-23 by David Moylan
The 606 can act as a master and also put out pulses for the toms so you
can use it to clock a sequencer.  I haven't used the two simultaneously
but it should work in theory.
Dave
>  >Hello,
>  >with the 303.
>  >Thanks,
>  >Dave
Re: TB-303 with MOTM...
Yeah...
I don't have a 606 707 808...I was just hoping there was something in the MOTM and
friends system that would help with the 24 pulse per.1/4 note problem.
Anything in the 650 that could help?
Dave
> Dave
> >  >Hello,
> >  >with the 303.
> >  >Thanks,
> >  >Dave
2008-07-23 by Mark
On 7/23/08, loopcycle put forth:
Really??  I wonder if that has to do with the increased availably of
percussion modules, and the decline of hardware samplers.  A
hardware sampler with individual outs can be used to trigger analogue
drum synths, and is velocity sensitive, just like a TR-707.  Also, as
a 707 is all digital, its function as a sound module could be
replaced with a hardware sampler.  Nowadays, no one makes hardware
samplers (except Akai MPC units) and the ones that were made are no
longer supported via software.
On 7/23/08, David Moylan put forth:
It also works in reality.  The issue with TR-606's is that people
keep buy them to hack them apart thinking they can somehow mod the
poor little things into an 808.
http://www.prepal.com/data/Roland.htm
2008-07-24 by Suit & Tie Guy
you can thank circuit bending for that i believe.
i saw a circuit-bent Kurzweil K2000 on ebay a few weeks ago. i wonder
how long it will take for those to hit 2 grand again.
Suit & Tie Guy
suitandtieguy.com
stgsoundlabs.com
2008-07-24 by Koos Fockens
To me the K2000 is worth the 2 grand, still :-)
hence my signature on my blog as K2K Koos , I love the K2000 (and it's successors), and
I'm responsible for others purchasing one too due to my continious nagging and praising
the K2000. In my eyes a worthy digital counterpart to all things analog, and still one of the
most powerful digital synthesis systems on the planet. :-)
> Suit & Tie Guy
> suitandtieguy.com
> stgsoundlabs.com
