Whoa! Sorry Richard! I guess the mind does really start to go after 50 . .
it seems sometimes that some of the stuff I type was typed by someone else!
I'm not sure if the filtering inlet will really be worth the extra bucks
either. I guess if I ever find myself doing some hard core German industrial
music and the electric drill and cutoff saw are plugged into the same
outlet, it might help keep the line noise out of the synth . . . but . . .
maybe wouldn't be desirable in that situation anyway! ;-)
Talk to you soon, R I C H A R D ;-)
John
Sent: Saturday, September 06, 2008 3:48 PM
To: John L Rice
Cc: 'sduck409'; motm@yahoogroups.com
Subject: Re: [motm] Switch for 900?
Um, that would be Richard Brewster ;->
I looked at inlets with line filtering, too. I am not sure what sorts
of application require such filtering. It seemed to me that it would
not add a lot of benefit to a MOTM system.
Richard Brewster
http://www.pugix.com
John L Rice wrote:
> Hi,
> Check out David Brewster's site here
> http://pugix.com/synth/portable-rack-cabinets/ He mentions one he used
> that is similar: " combination AC inlet, power switch and fuse, Schurter
> IEC320 AC I, (Mouser 693-4304.6090) for $9.00"
> Inspired by David's site I'm using similar cabinets and power supply
setup.
> I decided to get 'fancy' and use a more expensive AC inlet that has line
> filtering, even though it may not be of any real value (I whole heartedly
> believe in over kill! ;-)
http://www.alliedelec.com/Search/ProductDetail.aspx?SKU=6894156&MPN=864-03%2
> f003&R=6894156&SEARCH=6894156&DESC=864-03%2f003 It's $30 plus tax and
> shipping though!!!! ;-( Besides filtering it has voltage selection and
> since the PowerOne can accept 120 or 220 AC, I thought I would wire it up
> with an inlet that could be switched. (I've NEVER traveled to England or
> Japan etc and have no plans to do so but . . . obsessive compulsive
behavior
> doesn't like to be ignored! ;-)
> If you look at Allied's main page for power inlets they show a 'Top
seller'
> for $8.50 that looks like it should work too. And there is a mind boggling
> TON of different models to choose from!
http://www.alliedelec.com/search/SearchResults.aspx?N=4294821653&SKU=689-415
> 6&sid=11C342467F33
> Best of luck!
> John l Rice
> From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of
> sduck409
> Sent: Friday, September 05, 2008 5:10 PM
> To: motm@yahoogroups.com
> Subject: [motm] Switch for 900?
> Does anyone know a mouser/digikey number for the switch that's used in
> the 900 power supply? I've got everything I need for the power supply
> in this new cabinet I'm building except for the switch - and as
> everything else in it is up to motm specs, I'd like the switch to be too.
> Thanks!
