650 OS Update?
2008-12-01 by James Elliott
Paul, is there any news on the 650 OS update to resolve outstanding issues? Thanks, Jim ________________________________
From: James Elliott <johans121@...> To: motm@yahoogroups.com Sent: Wednesday, June 18, 2008 12:56:03 AM Subject: Re: [motm] 650 OS Update Status.... Here's the details of a bug that I turned in last year which causes my 650 to "crash". Hopefully this gets addressed in the next update as it is frustrating to no end. -Jim Paul, you've asked the list to send you any errors / descriptions of funky behavior that we encounter. I've already sent you a general description of these problems on 10/13, and I will go into more detail here. General Problem: My 650 quits responding to midi when I send midi cc's to control aux1. When I say quit responding I mean that the output jacks do not transmit a signal - the midi LED still responds to midi. One of two things happens once the 650 is in this state. 1) If I perform the following actions, then the 650 begins to respond to midi again (however it will lock up again if I send midi cc's to aux1) -Press "ESC" -Scroll to, and then select, "Module Actions" -Scroll to, and then select, "Load Patch" -and finally, load a patch 2) If I don't follow the steps above, I get various assert errors depending on different buttons that I press -L612: I get this error when I press "Enter" after a lockup -L2039: When I press "Inc" after a lockup -L2167: When I press "dec" after a lockup -L548: First I press "ESC", which allows me to scroll through the top level menu, then press "Enter" on any of the second level menu items My 650 is setup as follows: -Global options: 1) Voice Type - 1/1/1/1 2) CtrlMidi Chan - 1 3) Trig PWM - 10ms 4) VelScale - 8 Volts 5) Backlight - Auto 6) TunTable - 12 Tone 7) Note Inv - Off 8) Priority - LastNote 9) Clock - Internal 10) IClk BPM - 120.0 11) Midi Clk - Transmit 12) Patch Rx - Disabled (I also tried enabled, whatever that does?) 13) SysexSys ID=Global -VoiceGroup 1 Settings: 1) VG1 Midi Chan - 1 2) VG1 Allc - Solo 3) VG1Glide - Off 4) VG1PBend - 24 5) VG1GType - Normal 6) VG1 V/T - Velocity 7) VG1 Aux - CC12 (Tried others as well with the same issue resulting) 8) VG1AuxSc - 8 Volts -VoiceGroups 2 - 4 are set up exactly like group 1 except that the PBends are set to 0, and the Aux Midi CC's are set to different values (13, 14, 15). -Both Arps are turned off. **This also happens in other other voice modes as well 4/poly1, 4/poly2, 2/2/poly1, etc....... I really hope this gets fixed in the next patch release because having one of the 4 aux outs messed up sucks. Other than this problem, the 650 is a pretty cool module. -Jim ----- Original Message ---- From: Paul Schreiber <synth1@...> To: motm@yahoogroups.com; James Elliott <johans121@...> Sent: Wednesday, June 18, 2008 12:20:53 AM Subject: Re: [motm] 650 OS Update Status.... Hopefully Jeffrey will step in and give us an update. I have not heard from him in a while. Meanwhile: the majority of the issues are using external clock to drive the arpeggiators and using Voice Group 1/1/1/1 (4 independent MIDI channels). The Voice Group bug seems to be if you change from/into 1/1/1/1 mode. I think if you *start* there (the default patch) you are OK. I have not heard of any other bugs/crashes except in these 2 cases. If anyone has other bug to report, please do so. Paul S. ----- Forwarded Message ---- From: James Elliott <johans121@...> To: motm@yahoogroups.com Sent: Saturday, October 13, 2007 12:13:47 AM Subject: [motm] 650 Aux 1 Bug? I am encountering a very frustrating issue with my new 650. It seems as if I control aux 1 with a midi cc (as anyone would) my 650 becomes unresponsive to midi until I reload a patch. If I press enter on global options while in this state, I get an "Assert LXXXX" error message (they have been different each time, depending on what buttons I hit after this happens - the one I am starring at right now is L2028). When I get the error message, I have to power off my 650 completely to get it to work again. can't quite figure out what is causing this to happen. The only thing I am doing is sending cc information to control aux 1. This does not happen with aux2, 3, or 4. I am in 1/1/1/1 mode with all voices receiving on channel 1. Help! Any ideas!!??!! -Jim .
