MOTM
Scope question
Scope question
2009-01-29 by jneilnyc
I finally sat down tonight at got my Tektronix to give me some
waveform views of one of my oscillators.  There was more than a little
trial-and-error at first, but once I got in the ballpark I was able to
zero in on clear, static waveforms that changed shape in predictable
and expected ways, which was immensely satisfying (and will no doubt
impress my musical buddies, for whom a MOTM cabinet is already like
seeing something out of Close Encounters - this now adds that last mad
scientist touch).
And I got the onboard frequency counter working, which is a nice plus.
All this was done using a rather painful method whereby I clipped the
ground to one exposed terminal on the end of a phone cable and touched
the probe to the other.  While this worked, it was not at all easy to
do one-handed, and clearly not a long-term methodology.  What I really
want is to make this kind of connection permanent, ie just have some
sort of probe terminating in a phone plug that I can tap into any jack
without worrying about fiddly connections.  Does such a thing exist,
either ready-to-use or in some combination of probes+adaptors?
What do people who know what they're doing do?  (he said, and not for
the first time...)
Thanks!
JN
Re: [motm] Scope question
2009-01-29 by Stephen Drake
I went to radio shack and bought a bunch of bnc jacks of various types, and attached the business end of a patch cord to one of them. I also made a homebrew probe by taking a switchcraft jack and attaching wires terminating in alligator clips to the appropriate terminals. With these 2 tools, I'm covered. Note - this is NOT what people who know what they're doing do necessarily - consider the fact that i bought my scope on ebay for 21$ (a nice, fully functional heath). Whenever I visit any of our local electronics stores, I contemplate buying some real probes, but then contemplate having a few extra dollars left over, and pass.
scientist touch).
the first time...)
Thanks!
JN
Stephen Drake
sduck409@...
makeme1witheverything@...
2009-01-29 by David Abbey
Beg, borrow, make or buy yourself a coaxial cable with a BNC connector on at least one end.  Solder a 1/4" phone plug to the other end (tip to center conductor and sleeve to the braid, but be careful not to over heat the braid and melt the dielectric).  You can break out a signal with a multiple by routing your signal into one jack, taking it out of another in that multiple and plugging your 'scope cable into a third.  I made 2 for my 'scope (A and B channels).  I also made one with bananna plugs on one end to use with my DMM.
To: motm@yahoogroups.com
Sent: Wednesday, January 28, 2009 8:24:37 PM
Subject: [motm] Scope question
scientist touch).
the first time...)
Thanks!
JN
Re: Scope question
I was hoping it was as simple as this!  But seeing all the funky
looking probes out there with all the odd connectors and built-in
electronics I just assumed that I was being naive thinking I could
just make a cable.
The Tektronics probes that came with my scope have BNC connectors with
additional contact pins coming out of them - I take it these aren't
necessary in a homebrew cable?
> From: jneilnyc <jneil@...>
> scientist touch).
> the first time...)
> Thanks!
> JN
Re: [motm] Re: Scope question
I wouldn't wreck your Tektronics probes, you might need it to poke around a circuit board in the future!  I thought you just wanted a way to look at an output easily.  Try this link:  http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=683059&    You could cut the RCA end off and put a 1/4" plug or get a RCA to 1/4" plug adapter (Radio Shack has these).   Can't really go wrong for $4+S&H.
Sent: Wednesday, January 28, 2009 10:50:04 PM
Subject: [motm] Re: Scope question
just make a cable.
> ____________ _________ _________ __
> To: motm@yahoogroups. com
> scientist touch).
> the first time...)
> Thanks!
> JN
RE: [motm] Re: Scope question
2009-01-29 by JAMES GALLANT
The way I did it way too many moons ago was to get a BNC to RCA adaptor and then use a cable with an RCA connector on one end and a 1/4" connector on the other. Another option is BNC-RCA adaptor --> RCA-RCA cable --> RCA-1/4" adaptor.
James
Date: Thu, 29 Jan 2009 05:50:04 +0000
just make a cable.
> scientist touch).
> the first time...)
> Thanks!
> JN
Re: Scope question
This might be the ticket:
http://www.testpath.com/Items/BNC-Female-to-14-in-Audio-Phone-Plug-Adapter-112-130.htm
>                   James
> To: motm@...: jneil@...: Thu, 29 Jan 2009 05:50:04 +0000Subject:
funkylooking probes out there with all the odd connectors and
built-inelectronics I just assumed that I was being naive thinking I
couldjust make a cable.The Tektronics probes that came with my scope
have BNC connectors withadditional contact pins coming out of them - I
take it these aren'tnecessary in a homebrew cable?--- In
motm@yahoogroups.com, David Abbey <abbeysynth@> wrote:>> Beg, borrow,
make or buy yourself a coaxial cable with a BNCconnector on at least
one end. Solder a 1/4" phone plug to the otherend (tip to center
conductor and sleeve to the braid, but be carefulnot to over heat the
braid and melt the dielectric). You can breakout a signal with a
multiple by routing your signal into one jack,taking it out of another
in that multiple and plugging your 'scopecable into a third. I made 2
for my 'scope (A and B channels). Ialso made one with bananna plugs on
one end to use with my DMM.> > > > > ________________________________>
From: jneilnyc <jneil@>> To: motm@yahoogroups.com> Sent: Wednesday,
January 28, 2009 8:24:37 PM> Subject: [motm] Scope question> > > > I
finally sat down tonight at got my Tektronix to give me some> waveform
views of one of my oscillators. There was more than a little>
to> zero in on clear, static waveforms that changed shape in
predictable> and expected ways, which was immensely satisfying (and
will no doubt> impress my musical buddies, for whom a MOTM cabinet is
already like> seeing something out of Close Encounters - this now adds
that last mad> scientist touch). > > And I got the onboard frequency
counter working, which is a nice plus.> > All this was done using a
rather painful method whereby I clipped the> ground to one exposed
terminal on the end of a phone cable and touched> the probe to the
other. While this worked, it was not at all easy to> do one-handed,
and clearly not a long-term methodology. What I really> want is to
make this kind of connection permanent, ie just have some> sort of
probe terminating in a phone plug that I can tap into any jack>
without worrying about fiddly connections. Does such a thing exist,>
either ready-to-use or in some combination of probes+adaptors? > >
What do people who know what they're doing do? (he said, and not for>
the first time...)> > Thanks!> JN>
RE: [motm] Scope question
2009-01-29 by Adam Schabtach
Aside from all of the suggestions that have been aired for connecting a
1/4"audio plug to a BNC connector, there's another solution that's somewhat
more flexible: buy a scope probe with a clip-on probe cover, then clip it to
a 1/4" plug with its shell removed. This will give you hands-free operation
with both the 1/4" plug and anything else you need to look at with a scope.
Here's a random example of what I'm talking about:
http://www.testpath.com/Items/Passive-Oscilloscope-Probe-15MHz-X1-110-564.ht
m
(No, I've never used that particular probe. It was just the first example I
found.)
--Adam
  _____
From: motm@yahoogroups.com [mailto:motm@yahoogroups.com] On Behalf Of
jneilnyc
Sent: Wednesday, January 28, 2009 8:25 PM
scientist touch).
the first time...)
Thanks!
JN
2009-01-29 by Dave Manley
The extra pins on a tek scope probe  typically indicate to the
scope what type of probe is attached, specifically the
attenuation of the probe (usually x1 or x10).  This allows the
on screen display of voltage levels (assuming your scope
supports that) to be scaled appropriately.  So when you measure
a 5V signal with your x10 probe, the scope displays it as
5V and not 0.5V.
All you need (as others have mentioned) is a BNC cable with
an appropriate plug on the end.  Go buy a 6' to 12' BNC to BNC
cable, and then cut it in half.  Put 1/4 plugs on the cut ends
and you have two cables to hook up your scope and make
lissajous patterns...
Date: Wednesday, January 28, 2009, 9:50 PM
just make a cable.
> scientist touch).
> the first time...)
> Thanks!
> JN
2009-01-30 by David Abbey
lissajous patterns...I have a copy of Don Lancaster's Active Filter Cookbook and in it he describes "Quadrature Art".  I tried it with my MOTM-420 filters, one set to High Pass and the other to Low Pass.  Connected one to the vertical amp and the other to the horizontal amp.  Using an oscillator or 2 and fiddling with the resonance can produce some pretty spectacular results.
D. Abbey
To: motm@yahoogroups.com; jneilnyc <jneil@...>
Sent: Thursday, January 29, 2009 12:44:19 PM
Subject: Re: [motm] Re: Scope question
5V and not 0.5V.
just make a cable.
> scientist touch).
> the first time...)
> Thanks!
> JN
2009-01-30 by Richard Brewster
I've been getting by with the simple approach of just clipping a 10x
probe to a 1/4-inch plug without its housing.  I like the idea of
preserving the impedance features of the probe, rather than just
connecting directly to the scope BNC input.
Richard Brewster
http://www.pugix.com
> a 1/4"audio plug to a BNC connector, there's another solution that's
> somewhat more flexible: buy a scope probe with a clip-on probe
> cover, then clip it to a 1/4" plug with its shell removed. This will
> give you hands-free operation with both the 1/4" plug and anything
> http://www.testpath.com/Items/Passive-Oscilloscope-Probe-15MHz-X1-110-564.htm
> example I found.)
> --Adam
>     *From:* motm@yahoogroups.com [mailto:motm@yahoogroups.com] *On
>     Behalf Of *jneilnyc
>     *Sent:* Wednesday, January 28, 2009 8:25 PM
>     *To:* motm@yahoogroups.com
>     *Subject:* [motm] Scope question
>     scientist touch).
>     the first time...)
>     Thanks!
>     JN
2009-01-30 by Dave Manley
You can always put a series resistor in the plug body if you're really
concerned.  Most scopes have a 1M input impedance.  The method
I described is really a X1 probe with some pF's of capacitance/ft due to the
coax.  For audio frequencies it probably isn't going too matter much.
Put a 9M resistor in series in the plug and you have a X10 probe.
Note many Tek scopes aren't going to recognize it as a X10 probe
due to the autosense mentioned earlier.
(If you really want to compensate it, you can put a little (variable)
cap inside the plug body as well.)
--- On Thu, 1/29/09, Richard Brewster <pugix@...> wrote:
Subject: Re: [motm] Scope question
To: lists@...
Cc: motm@yahoogroups.com
Date: Thursday, January 29, 2009, 4:37 PM
Richard Brewster
http://www.pugix. com
> http://www.testpath .com/Items/ Passive-Oscillos cope-Probe- 15MHz-X1- 110-564.htm
> example I found.)
> --Adam
>     *From:* motm@yahoogroups. com [mailto:motm@yahoogroups. com] *On
>     Behalf Of *jneilnyc
>     *To:* motm@yahoogroups. com
>     scientist touch).
>     the first time...)
>     Thanks!
>     JN
2009-01-30 by George Kisslak
This is the technique that I have used with success.
George
> give you hands-free operation with both the 1/4" plug and anything else
> example I found.)
> --Adam
<snip>
Re: Scope question
2009-01-30 by Charles Osthelder
I've got a mult panel (a copy of the MOTM-910 cascaded multiple) that
I made with two BNC connectors.  This allows me to look at any AC or
DC voltage patched in the system or add an external voltage from my
lab equipment.
You'll need a multiple connection panel sooner or later...
Chub, destroyer of ivy.
2009-01-31 by David Abbey
Wish I'd thought of that!
D. Abbey
Sent: Friday, January 30, 2009 1:40:02 PM
lab equipment.
2009-01-31 by Richard Brewster
Have you got a part number for a BNC connector that fits into a 3/8-inch
jack hole?
Richard Brewster
> lab equipment.
Re: Scope question
2009-02-04 by Richard Brewster
Chub meant to send this to the list.
> OK, I should have replied to the group.  I answered Richard from my
> home email:
> "Amphenol part number 112424 (Mouser # 573-112424) is the closest
> you'll get, as far as I know.  You really want a "D"-shaped hole,
> though.  Otherwise you'll be re-tightening the connector a lot and
> that means pulling the panel.
> I made my own panel.  Two BNCs, each wired to three 1/4" sockets.
> Below that are eight  1/4" sockets in the MOTM cascade arrangement."
> This actually gets a lot of use.  There is a small oscilloscope
> patched into the Engine of Chaos at all times.  When people come to
> see it, I can easily teach them about waveforms that they can see as
> well as hear. It's also nice to understand the results I'm hearing
> when things aren't as expected - you think you've got a bad module
> only to find that your patch makes a noise out of the range of human
> hearing!  Trust me, I'm not always too clever...
> You can buy a simple banana-to-BNC adapter for patching in modules and
> test gear with that format as well. My favorite is the Pomona 1296 -
> Mouser part number 565-1296.  It allows multiple stacks and the banana
> jacks are also binding posts for bare wire.  $13.70 apiece but worth it!
> Remember - the more wires and cables you have hanging off your system,
> the more likely that people will just leave you alone in your room.
> Chub - from deep within the evil lair
> 3/8-inch
>> jack hole?
>> Thanks,
>> Richard Brewster
>>> lab equipment.
Re: Scope question
2009-02-05 by jneilnyc
Thanks to everyone who responded, it was most helpful.  I did end
up getting a couple BNC->phone adaptors and sticking them on some
cheap cables, and things are working fine.  I think the actual
measurements are probably off by 10x or whatever, but that's not
really what I need it for scoping MOTM audio.
Speaking of which, I already had a chance to put it to good use the
other day (and by good I mean "as something other than a light show")...
I was getting confusing results from a module as seemingly obvious as
the 910 multiple -- I had misinterpreted the less-than-crystal-clear
note on the product page and signals were showing up where I didn't
expect them and vice versa.  Five minutes on the scope and I was able
to see exactly where signals were coming out correctly and where they
were adding together unpredictably, and eventually I divined the
mysteries of the jack logic.
> >                   James
> > To: motm@: jneil@: Thu, 29 Jan 2009 05:50:04 +0000Subject:
