3310s, multiples, and joysticks WAS: some other s**t
2000-02-13 by J. Larry Hendry
> From: JWBarlow@... > Well, it would be nice if Doug could find some more 3310s, > and nice to see them end up in some MOTM modules. Absolutely. > Though, installing my old radio in my "new" truck may > cause me to increase my (alcohol) consumption substantially. Duct tape it under that dash like a real man ! > > simple 4 X 4 multiple. > > Hey! Wasn't I supposed to drill a similar panel for PaulBr? > I may be totally wrong.... Yes, you did volunteer. I made one for myself just as kind of an experiment to try the "white paint for lines process." It worked great. And, since my wood case will probably be a fall 2000 project, I needed something to tie me over to the magic bus days. Besides, I know I pool of quite a few guys I can probably sell it to for a reasonable price when I'm done using it. I will be taking my MOTM system to the Midwest Analog Heaven gathering this year and I am trying to get it 100% user friendly. > >P.S. That joystick panel is my next drillin' project. > > I'd be very interested to hear what this panel is about, and how it develops. Well, you and I have discussed this before. But, essentially, there will be four pots in MOTM spacing fashion across the top two rows. Below that will be the joystick, sticking straight out. Below that will be 4 jacks along the bottom row. (2 unit panel of course). The controls will be X - gain and Y - gain to control the output voltage range and X trim (or offset) and Y trim to adjust the DC output to zero (or some other voltage) when the joystick is in its center resting position. The output jacks will be X + X - Y + and Y -. I intend to use simple op-amps to buffer the output and provide inversion. So, joystick movement will produce positive going and negative going voltages at the same time (equal and opposite). That's pretty much the plan. Larry Hendry
