MOTM
VC EG: Flogging a Deceased Equine
2000-02-12 by Tkacs, Ken
The discussion of a VC EG is interesting. First, the idea of controlling a
sound's envelope with 'velocity' or other 'burst' of performance energy is
fundamental to creating a musical sound. Second, it has RARELY been done in
the history of modular synthesis. After all, touch/velocity sensitivity was
very rare in synthesis before MIDI.
Let me also note that many psychoacoustic investigators have stated firmly
that the *envelope* of a sound contributes more to its unique identifyable
characteristic that any other aspect, even though synthesists tend to be
continue to be more concerned with harmonic content that amplitude contour.
The thing is, simply opening up 4 jacks to control the parameters of an ADSR
doesn't do it 'all' for making a sound natural. We almost need some kind of
intervening scaling module.
For instance, if I add more energy to a sound, depending upon the modelled
medium, I would expect that its attack would shorten, it's decay likewise
(unless the decay were substituting for the sustain, as in a piano), and the
release would lengthen.
This is a crude, choppy, post-Friday-night-martini plea, I guess, for an
interpolating module whereby one could input a simple velocity CV and tailor
its effects on the overall sound coming from the modular.
The fact is, psychoacoustic research has shown that playing 'harder' on
acoustic instruments does more for the envelope of the 'filter' than of the
'VCA'. Playing harder on a xylophone *seems* to make it louder, but in
reality is does more to increase the amount of energy in the higher
frequency areas than changes the actual measured amplitude.
Nighty-nite, all.
Zzzzzzzzzz...
Re: VC EG: Flogging a Deceased Equine
2000-02-12 by JWBarlow@aol.com
In a message dated 2/11/2000 9:18:53 PM, Ken.Tkacs@... writes:
>ADSR
>of
Actually, I think that's what I just said (except I think the scaling module
is so important that I'd build it right in to the EG) -- take one input and
route it to four different reversing attenuators to independently control the
A, D, R phases of the envelope. I really do think these routing-scaling-pots
are a good idea.
I agree! I may have underemphasized what I consider the important part of my
proposed 3310 module -- the SINGLE VC A, VC D, VC R, INPUT and the associated
THREE reversing attenuators. I consider the four unattenuated VC inputs to be
much less interesting or useful.
Hey! Pour me one while you're at it!
JB
2000-02-12 by J. Larry Hendry
> From: JWBarlow@...
my
associated
to be
This makes perfect sense to me (except the 3310 part).  As I considered all
the recent hub-bub about VC EGs, I could never really make the connection
(any Mr. Obvious fans out there?)  But, John has made it crystal clear to
me here.  One voltage, three reversing attenuators - Yes, I like the sound
of that.  And the idea that you would normal them through individual input
jacks in case you wanted individual CV control to satisfy the masses.
However, for me, I can see one voltage doing the whole trick (like John
said).
Larry (pouring John a cold drink) Hendry
RE: VC EG: Flogging a Deceased Equine
Great idea! I like this (except as Larry has said, the 3310 specialty chip
seems frightening). Why no VC of Sustain, I wonder?
Here's your martini!
(Larry, whay are you up so late?)
To: motm@onelist.com
Sent: 02/11/2000 11:50 PM
Subject: Re: [motm] VC EG: Flogging a Deceased Equine
Take one input
and
control the
