MOTM
jb - vc eg`s
jb - vc eg`s
2000-02-13 by DAVEVOSH@aol.com
to john barlow :
john,
just took a quick follow-up look at some literature i have from the "other
guys" and i was surprised to see that they didn`t have a "vc all" input !!!
i was surprised as it is easy to do and an inexpensive addition. on the brand
"D", there even looked to have been sufficient panel space for the additional
pot/knob and jack. can`t believe they missed it although the "feature" is
still there if you use a multiple to send the voltage to all the inputs
simultaneously. kludgey but at least do-able.
did you say you had a s**** tkb ? then the individual inputs might have some
value to you if you used the 4 output voltages to control the 4 parameters
giving you 16 selectable, preset envelope contours as one simple example.
best,
dave
