Re: [motm] Osc Controller
2000-03-16 by jwbarlow@aol.com
Something makes me think that Paul isn't a big enthusiast of rotary switches. Call it a hunch! JB In a message dated 3/15/2000 8:39:39 PM, jlarryh@... writes:
>I went through and sized up the resistors that were required to actually >change out the VCO course tune pot to an 11 position octave switch >(actually hitting the 5ths in between).
2000-03-16 by J. Larry Hendry
I went through and sized up the resistors that were required to actually change out the VCO course tune pot to an 11 position octave switch (actually hitting the 5ths in between). I'll see if I can dig that up. I have not modified one of mine yet, but I have considering it a couple of times. I was going to use the best trimmers I could get and just preset the switch for octaves and 5ths. The 12 position was going to short out part of the resistance in the "fine tune" summing resistor so a "course" variable adjustment could still be available there. These are just THOUGHTS, not plans. "Standard dumb stooge disclaimer applies" However, once Paul actually makes that highly accurate DC mixer, it would be easy to mix the incoming 1/volt per octave voltage with one from your resistor divider. However, now that I think about it, here is a decent idea: Use one of the FM inputs to do your octave switching. Since they are not 1/v octave, some measurement would need to determine what voltage produced the octave shift desired with the predetermined FM knob in the 100% position. Once the voltages were determined, you could build a simple voltage divider with trimmers, and a rotary switch to select octaves up or down and do the whole thing without any modification to the best VCO on the planet. In fact, I like this idea. I am gonna take some measurements myself and see what gives. Great idea Nathan. A simple 1U panel could be made up with up to 4 rotary switches and 4 output jacks so you could add octave switching anytime you wanted by just plugging in. However, I think I would only put about 2 in a panel and make the trimmers (front panel accessible). They make very nice panel mount holders for those 15 turn trimmers that look very nice. And trimming necessary could be easily done. Larry (off to experiment) Hendry ----------
> From: Nathan Hunsicker <nate@...> > To: MOTM Newsgroup <motm@onelist.com> > Subject: [motm] Osc Controller > Date: Wednesday, March 15, 2000 9:20 PM > > From: Nathan Hunsicker <nate@...> > > Does anyone know a simple circuit I could build to drop an input voltage > in 1 volt steps. What I want to do is build an oscillator controller to > switch octaves by flipping a series of switches or by turning a rotary > switch. I'd like to be able to tune all my VCO's the same and then use > this unit to lower the pitch by octaves, similar to the footage switch > on a moog 921. Is this possible? -Nate > > ------------------------------------------------------------------------ > PERFORM CPR ON YOUR APR! > Get a NextCard Visa, in 30 seconds! Get rates as low as > 0.0% Intro or 9.9% Fixed APR and no hidden fees. > Apply NOW! > http://click.egroups.com/1/2121/2/_/529958/_/953176758/ > ------------------------------------------------------------------------ > >
2000-03-16 by davevosh@aol.com
In a message dated 00-03-15 23:27:21 EST, you write: << Something makes me think that Paul isn't a big enthusiast of rotary switches. >> john, in his infinite wisdom paul has done something with the motm vco that matches my compositional esthetic. the single thing i hate the most about my doepfers vco`s are the "range" ( octave) switches. a stable, wide range vco is limited by their addition, IMHO. yes, they make conventional pitch / note music easier but the whole idea of voltage control is freedom. since what i like to do is more "register" based ( hi / med / lo ) droney "dream machine" stuff, having a wide available range on the vco`s is desirable. in my shameful past as a "serge-ist", i found their vco`s to be acceptably stable and the wide, unswitched range, essential !!! paul, you got this one right, IMHO, on the vco`s ........ best, dave v.
2000-03-16 by ivancu@aol.com
In a message dated 3/16/2000 6:22:36 AM, davevosh@... writes: << the single thing i hate the most about my doepfers vco`s are the "range" ( octave) switches. a stable, wide range vco is limited by their addition, IMHO. yes, they make conventional pitch / note music easier but the whole idea of voltage control is freedom. >> AGREED! The octave switching should be on the controller-end, not at the VCO. That way us "alternative controller" guys who don't think along the lines of keyboards aren't limited. Somewhere along the line somebody made a compromise choice and decided to use a keyboard to control a synthesizer. But a synthesizer inherently is not a keyboard instrument. If you keep thinking along the keyboard paradigm you end up where MIDI is at, where it is very difficult to continuously play "between the keys". This is very limiting and instead of expanding the electronic music universe, attempts to constrain it. Ok, rant off. Ivan
2000-03-16 by Nathan Hunsicker
I was thinking more along the lines of easy switching of single oscillators during a stage performance. I didn't want to modify the 300VCO, it's perfect the way it is, my only problem is having to retune one oscillator if i want to feed two off the same cv and drop one of them 1 or 2 octaves. -Nate
> From: >ivancu@... > > >In a message dated 3/16/2000 6:22:36 AM, davevosh@... writes: > > > ><< the single thing i hate the most about my doepfers vco`s are the "range" > >( octave) switches. a stable, wide range vco is limited by their addition, > >IMHO. yes, they make conventional pitch / note music easier but the whole > >idea of voltage control is freedom. >> > > > >AGREED! The octave switching should be on the controller-end, not at the > >VCO. That way us "alternative controller" guys who don't think along the > >lines of keyboards aren't limited. > > > >Somewhere along the line somebody made a compromise choice and decided to use > >a keyboard to control a synthesizer. But a synthesizer inherently is not a > >keyboard instrument. If you keep thinking along the keyboard paradigm you > >end up where MIDI is at, where it is very difficult to continuously play > >"between the keys". This is very limiting and instead of expanding the > >electronic music universe, attempts to constrain it. > > > >Ok, rant off. > > > >Ivan > > > >
I wanted to make a seperate module which could be bypassed if it was not desired. Something that would go inline between the cv controller and the osc. -Nate
> From: >Nathan Hunsicker <nate@...> > > >I was thinking more along the lines of easy switching of single oscillators > >during a stage performance. I didn't want to modify the 300VCO, it's > >perfect the way it is, my only problem is having to retune one oscillator > >if i want to feed two off the same cv and drop one of them 1 or 2 octaves. > >-Nate > > > >> From: > >>ivancu@... > >> > >> > >>In a message dated 3/16/2000 6:22:36 AM, davevosh@... writes: > >> > >> > >> > >><< the single thing i hate the most about my doepfers vco`s are the "range" > >> > >>( octave) switches. a stable, wide range vco is limited by their addition, > >> > >>IMHO. yes, they make conventional pitch / note music easier but the whole > >> > >>idea of voltage control is freedom. >> > >> > >> > >> > >>AGREED! The octave switching should be on the controller-end, not at the > >> > >>VCO. That way us "alternative controller" guys who don't think along the > >> > >>lines of keyboards aren't limited. > >> > >> > >> > >>Somewhere along the line somebody made a compromise choice and decided to use > >> > >>a keyboard to control a synthesizer. But a synthesizer inherently is not a > >> > >>keyboard instrument. If you keep thinking along the keyboard paradigm you > >> > >>end up where MIDI is at, where it is very difficult to continuously play > >> > >>"between the keys". This is very limiting and instead of expanding the > >> > >>electronic music universe, attempts to constrain it. > >> > >> > >> > >>Ok, rant off. > >> > >> > >> > >>Ivan > >> > >> > >> > >> > > > > > > > > > >
2000-03-16 by Tkacs, Ken
I agree with all sides that have spoken out on the "Range Switch" issue. The synthesizer is *not* inherently a keyboard instrument, nor should it even be thought of as being equal tempered, or bound to discreet pitches at all! It's the most flexible sound shaping device in the history of musical instruments, and no design-time limitations or pre-conceptions should be imposed on it, if it can be helped. However, those looking for an octave or octave/fifths switch are just looking for another degree of control, and controls are good things. I certainly wouldn't modify my 300's directly, but I don't see the harm in the separate module idea. Perhaps a generic bias voltage module with discreet outputs that can produce the 0.5v steps needed for octave switching. Actually, I've been 'hankering' for a flexible quantizer module to turn continuous voltages into very accurate discreet ones (one not limited to 12 notes per octave, something adjustable for accurate microtonality). I wonder if somehow a quantizer and a range controller for VCOs could be combined. Haven't thought this through, just tossing in my $0.02.
In a message dated 00-03-16 07:57:09 EST, you write: << The octave switching should be on the controller-end, >> ivan, actually as i ponder this, i could see a use for a "retro" module for the feature. for me, probably used for setting a range of modulation for filters and vca`s and such as opposed to vco`s. hence if i don`t think of it as "octave switching" and do in terms of biasing into a specific range, then it makes sense. the advantage of modulars, as the same module can be conceptualized both ways. its just a matter of what you like.... best, dave v.
In a message dated 00-03-16 08:59:44 EST, you write: << Something that would go inline between the cv controller and the >> nate, yes, i agree a separate module would be the right approach. best, dave
In a message dated 00-03-16 09:21:23 EST, you write: << Perhaps a generic bias voltage module with discreet outputs that can produce the 0.5v steps >> kenn, agreed! thats what i was trying to think in terms of in my previous post. best, dave
In a message dated 00-03-16 09:21:23 EST, you write: << accurate microtonality). I wonder if somehow a quantizer and a range controller for VCOs could be combined. >> kenn, i would think this is possible but tricky to coordinate. wouldn`t you have to get an accurate mix of the offset voltage and the quantizer output ? over a wide range of notes, that might be very hard to do. --- ???? --- best, dave p.s. most of my "microtonal" experience is from some experiments i did with a serge tkb used as a manual voltage controller with each of the 16 stages being tuned to the correct voltages for each frequency of whatever scale, 17, 19, etc.. possible with a dvm but works best after everythings been on for a while to stabilize. also, only limited ranges of available notes. still, it worked! best, dave v.
I'm still trying to devise a good method of working with microtonality and my modular. I've done some work with a Mirage-DSK running a customized microtonal OS, a Yamaha TX-81Z with my hand-created soundbanks for different tunings, and an Ensoniq ESQ-M with again banks of 40 sounds where each was hand-tweaked to give me microtonality. These three instruments have less-than-stellar tuning resolution for this kind of work, and were a bear to get to work together, but I was able to experiment a bit with this in the early 90's. I figure with a modular, microtonality should be easier, but it still has its own problems. I'm working toward using a Theremin as a controller, but I still want some discreet pitches in there. I'm always daydreaming about other non-keyboard controllers, or at least non-'piano' keyboards. I like the idea of the S-TKB, but don't have one. I also like the layout of a keyboard that was designed decades ago by some guy named Solar (sp?) that had white and black keys alternating-this allowed for not only a generic keyswitch layout, but one which allowed easy transposition and a greater pitch span with the hand as compared to a conventional 'piano' keyboard. I think he patented the idea and was looking for backing to produce acoustic pianos with it... doesn't seem like it ever got off the ground. I don't know how tricky it would be to make a quantizer module. As I understand it, this is a standard feature of the output sections of most sequencers, though, no? Otherwise they would be a major bitch to tune. Someone must have figured out how to make one stable. I guess making it variable and stable does throw a wrench into it, though.
-----Original Message----- From: davevosh@... [mailto:davevosh@...] Sent: Thursday, 16 March, 2000 11:47 AM To: motm@onelist.com Subject: Re: [motm] Osc Controller From: davevosh@... In a message dated 00-03-16 09:21:23 EST, you write: << accurate microtonality). I wonder if somehow a quantizer and a range controller for VCOs could be combined. >> kenn, i would think this is possible but tricky to coordinate. wouldn`t you have to get an accurate mix of the offset voltage and the quantizer output ? over a wide range of notes, that might be very hard to do. --- ???? --- best, dave p.s. most of my "microtonal" experience is from some experiments i did with a serge tkb used as a manual voltage controller with each of the 16 stages being tuned to the correct voltages for each frequency of whatever scale, 17, 19, etc.. possible with a dvm but works best after everythings been on for a while to stabilize. also, only limited ranges of available notes. still, it worked! best, dave v.
In a message dated 00-03-16 11:58:15 EST, you write: << As I understand it, this is a standard feature of the output sections of most sequencers, though, no? Otherwise they would be a major bitch to tune. >> kenn, my doepfer sequencer doesn`t have a quantizer built in. yes, "tuning" per se can be difficult or time consuming but to have the possibilities available for other tunings, etc. is worth the trade off. for those who need it, they do also have a separate module quantizer. as a separate module, it is available to be applied as a processor to any source of c.v., theremin controllers, etc.. again, thats the whole idea, open up the systems and let the possibilities multiply. best, dave v.
Oh, I would *definitely* want a quantizer to be *defeatable!* But it's nice to have it there for when you need it. I'm the first one to wave the flag for weird, sweepy, Theremin-style electronic music. But the ability to 'find' intervals is desireable. Let's face it---our VCOs respond to 1v/octave for a reason. (The octave, by any other name, is a physically meaningful relationship that is found in most (not all) musical cultures.)
-----Original Message----- From: davevosh@... [mailto:davevosh@...] Sent: Thursday, 16 March, 2000 12:46 PM To: motm@onelist.com Subject: Re: [motm] Osc Controller my doepfer sequencer doesn`t have a quantizer built in. yes, "tuning" per se can be difficult or time consuming but to have the possibilities available for other tunings, etc. is worth the trade off.
2000-03-16 by Dave Bradley
My thoughts on a dedicated "octave switch" type controller: I prefer a module that is generalized such that it can do several things. For this type of function, I'd use an adjustable voltage quantizer module. You can input any old dc control voltage, and adjust the output quantization to perfect octaves to handle your tuning chores. Then you can also use the module for general purpose quantizing. I'm going to diy one soon based on the old Polyfusion circuit while we wait for Paul's super duper ROM based microtuneable quantizer. Dave Bradley Principal Software Engineer Engineering Animation, Inc. daveb@...
> -----Original Message----- > From: ivancu@... [mailto:ivancu@...] > Sent: Thursday, March 16, 2000 6:57 AM > To: motm@onelist.com > Subject: Re: [motm] Osc Controller > > > From: ivancu@... > > In a message dated 3/16/2000 6:22:36 AM, davevosh@... writes: > > << the single thing i hate the most about my doepfers vco`s are > the "range" > ( octave) switches. a stable, wide range vco is limited by their > addition, > IMHO. yes, they make conventional pitch / note music easier but the whole > idea of voltage control is freedom. >> > > AGREED! The octave switching should be on the controller-end, not at the > VCO. That way us "alternative controller" guys who don't think along the > lines of keyboards aren't limited. > > Somewhere along the line somebody made a compromise choice and > decided to use > a keyboard to control a synthesizer. But a synthesizer > inherently is not a > keyboard instrument. If you keep thinking along the keyboard > paradigm you > end up where MIDI is at, where it is very difficult to continuously play > "between the keys". This is very limiting and instead of expanding the > electronic music universe, attempts to constrain it. > > Ok, rant off. > > Ivan > > ------------------------------------------------------------------------ > MAXIMIZE YOUR CARD, MINIMIZE YOUR RATE! > Get a NextCard Visa, in 30 seconds! Get rates as low as > 0.0% Intro or 9.9% Fixed APR and no hidden fees. > Apply NOW! > http://click.egroups.com/1/2122/2/_/529958/_/953211409/ > ------------------------------------------------------------------------ > >
Am I understanding corectly that a quantizer would only allow cv voltages corresponding to the 12 tone scale? If so, wouldn't this make any type of portamento sound more like running your fingers down a keyboard versus a nice smooth sound? -Nate
> From: >"Tkacs, Ken" <ken.tkacs@...> > > > > >Oh, I would *definitely* want a quantizer to be *defeatable!* But it's nice > >to have it there for when you need it. > > > >I'm the first one to wave the flag for weird, sweepy, Theremin-style > >electronic music. But the ability to 'find' intervals is desireable. Let's > >face it---our VCOs respond to 1v/octave for a reason. (The octave, by any > >other name, is a physically meaningful relationship that is found in most > >(not all) musical cultures.) > > > > > > > >-----Original Message----- > >From: davevosh@... [mailto:davevosh@...] > >Sent: Thursday, 16 March, 2000 12:46 PM > >To: motm@onelist.com > >Subject: Re: [motm] Osc Controller > > > > > > > >my doepfer sequencer doesn`t have a quantizer built in. yes, "tuning" per se > > > >can be difficult or time consuming but to have the possibilities available > >for other tunings, etc. is worth the trade off. > > > > > >
A simple one would, yeah. I would definitely want to at least scale the intervals, if not set them individually (which is apparently difficult for analog electronics to do without drifting, etc.). If you put a swept voltage through one and controlled a VCO with it, yes, you'd get a sound like you describe (assuming it was set to 1/12 volt steps). For Theremin players having a hard time finding that pitch, a quantizer is the answer. Then you could put the VC Lag module AFTER the quantizer to smooth it a little bit, but still have those solid in-tune pitch plateaus in there.
-----Original Message----- From: Nathan Hunsicker [mailto:nate@...] Sent: Thursday, 16 March, 2000 3:38 PM To: motm@onelist.com Subject: RE: [motm] Osc Controller Am I understanding corectly that a quantizer would only allow cv voltages corresponding to the 12 tone scale? If so, wouldn't this make any type of portamento sound more like running your fingers down a keyboard versus a nice smooth sound? -Nate
Back to Paul's Idea, how about a module that could produce 4 different adjustable fixed cv's? As long as the voltages are adjustable you could run the output into the fm2 jack on the 300 VCO. Setting # 1 could be 0V to allow the VCO to operate at its normal frequency, settings 2.3 and 4 could be set by ear to different intervals above the base frequency and then accessed at the touch of a button. This module would have to be ultra-stable in order to keep from drifting and what's the use of an ultra-stable VCO if your cv source is going to drift. -Nate
> From: >"Tkacs, Ken" <ken.tkacs@...> > > > > >A simple one would, yeah. I would definitely want to at least scale the > >intervals, if not set them individually (which is apparently difficult for > >analog electronics to do without drifting, etc.). > > > >If you put a swept voltage through one and controlled a VCO with it, yes, > >you'd get a sound like you describe (assuming it was set to 1/12 volt > >steps). > > > >For Theremin players having a hard time finding that pitch, a quantizer is > >the answer. Then you could put the VC Lag module AFTER the quantizer to > >smooth it a little bit, but still have those solid in-tune pitch plateaus in > >there. > > > > > > -----Original Message----- > >From: Nathan Hunsicker [mailto:nate@...] > >Sent: Thursday, 16 March, 2000 3:38 PM > >To: motm@onelist.com > >Subject: RE: [motm] Osc Controller > > > > > > > >Am I understanding corectly that a quantizer would only allow cv voltages > >corresponding to the 12 tone scale? If so, wouldn't this make any type of > >portamento sound more like running your fingers down a keyboard versus a > >nice smooth sound? -Nate > > > > > > > > > > > >
This is exactly what the module was supposed to do. Not surprising, since Paul proposed it after an identical earlier discussion about octave switching VCOs <g>! Dave Bradley Principal Software Engineer Engineering Animation, Inc. daveb@...
> > > From: Nathan Hunsicker <nate@...> > > Back to Paul's Idea, how about a module that could produce 4 different > adjustable fixed cv's? As long as the voltages are adjustable you > could run > the output into the fm2 jack on the 300 VCO. Setting # 1 could be 0V to > allow the VCO to operate at its normal frequency, settings 2.3 and 4 could > be set by ear to different intervals above the base frequency and then > accessed at the touch of a button. This module would have to be > ultra-stable in order to keep from drifting and what's the use of an > ultra-stable VCO if your cv source is going to drift. -Nate > >
Dave Bradley wrote:
From: "Dave Bradley"This is exactly what the module was supposed to do. Not surprising, since
switching VCOs !Dave Bradley
daveb@...>
> could run
Also, how do I search the onelist archives? every time i put in a search I get 27 or so messages from the last 2 months. -Nate Dave Bradley wrote:
> From: "Dave Bradley" <daveb@...> > > This is exactly what the module was supposed to do. Not surprising, > since > Paul proposed it after an identical earlier discussion about octave > switching VCOs <g>! > > Dave Bradley > Principal Software Engineer > Engineering Animation, Inc. > daveb@... > > > > > > > From: Nathan Hunsicker <nate@...> > > > > Back to Paul's Idea, how about a module that could produce 4 > different > > adjustable fixed cv's? As long as the voltages are adjustable you > > could run > > the output into the fm2 jack on the 300 VCO. Setting # 1 could be 0V > to > > allow the VCO to operate at its normal frequency, settings 2.3 and 4 > could > > be set by ear to different intervals above the base frequency and > then > > accessed at the touch of a button. This module would have to be > > ultra-stable in order to keep from drifting and what's the use of an > > > ultra-stable VCO if your cv source is going to drift. -Nate > > > > > > ----------------------------------------------------------------------- > > ----------------------------------------------------------------------- >
2000-03-18 by davevosh@aol.com
In a message dated 00-03-16 13:53:34 EST, you write: << I'm the first one to wave the flag for weird, sweepy, Theremin-style electronic music >> kenn, i guess that makes me second....... luckily, for me, intervallic relationships are of minor interest so its not a real problem. for folks doing "music", i concede the necessity. best, dave v.
