MOTM
RE: [motm] VCO concept...
2000-03-20 by Tkacs, Ken
That often gets called a "skew" control. I've often seen things like it on
LFOs (i.e., the Korg MS 'Modulation Generators'), but to my knowledge not on
an *audio* oscillator (Serge may have something that does this, I don't
remember).
I could be wrong, but I thought there was talk of a "shape" control
something like this for the upcoming MOTM 1u VCO...?
I don't have my MOTM-320 VCLFO yet---is this what happens to the Triangle
output when you sweep it's Shape control?
Sent:	Monday, 20 March, 2000 3:20 PM
To:	'motm@onelist.com'
Subject:	[motm] VCO concept...
I don't recall where I first heard about this idea / feature, but it sounds
really neat, and like the kind of thing that would be on a MOTM module.
There is a function I've seen that's sort of a PWM for triangle waveforms.
It sweeps the shape from sawtooth to triangle to reverse sawtooth smoothly.
Forgive the poor ASCII art, but this is the idea:
Any chance of seeing that on a future VCO?  Is this technically feasable?
Or am I daft and its already around?
* PBr
VCO concept...
2000-03-20 by Brousseau, Paul E (Paul)
(BTW, Hi, this is still Paul Brousseau.  Apparently my workplace decided
unannounced that outgoing e-mail is going to be from our lucent accounts
instead of the old mosaix account.  So this is still me.  Hi.)
--PBr
2000-03-20 by Dave Bradley
It's already a feature on the 320 LFO, and something similair is in the
works for the upcoming 310 micro VCO.
Dave Bradley
Principal Software Engineer
Engineering Animation, Inc.
daveb@...
> From: "Brousseau, Paul E (Paul)" <noise@...>
> it sounds
> smoothly.
> --PBr
Re: [motm] VCO concept...
2000-03-20 by hodad1@mindspring.com
on
> remember).
My micromoog (& I'm sure many other Moogs) has continously variable
waveshape.  Waveshape can also be set as a modulation destination.
I am pretty sure the triangle is the one waveform w/o waveshaping on the
320.  (someone
will undoubtedly correct me if I'm wrong.)  The shape control is great,
though, & pushing the 320 into audio range is highly recommended(by me,
anyway)
tomr
>  -----Original Message-----
> From: Brousseau, Paul E (Paul) [mailto:noise@...]
sounds
smoothly.
> * PBr
> PERFORM CPR ON YOUR APR!
> Get a NextCard Visa, in 30 seconds!  Get rates as low as
> 0.0% Intro or 9.9% Fixed APR and no hidden fees.
> Apply NOW!
> http://click.egroups.com/1/2121/3/_/529958/_/953583850/
Oh, okay-so the Triangle is fixed, but in essence the Sawtooth output is
really doing what would be done if you skewed the Triangle anyway.
Sent:	Monday, 20 March, 2000 4:28 PM
To:	motm@onelist.com
Subject:	RE: [motm] VCO concept...
Triangle output stays fixed, but Sine, Saw, and Pulse outputs are affected.
See for details:
http://www.synthtech.com/demo/shapes.gif
This shows a sawtooth morphing through a double freq triangle to a reverse
sawtooth. Get yer 320s if you haven't already, folks - this is very cool!
> From: "Tkacs, Ken" <ken.tkacs@...>
For those who joined the list after the big "micro VCO" discussion, attached
is an image depicting where we ended up. Single space, relatively
inexpensive, fixed triangle and manually variable (from square to saw)
outputs.
See for details:
Dave
RE: [motm] VCO concept.../also LFO
2000-03-20 by David Bivins
> 320.  (someone
> anyway)
> tomr
I agree completely! I've used it in audio range in a couple of tracks
already.
Also the pulse output makes a cool gate, synced via a trigger!
2000-03-21 by J. Larry Hendry
You got it Ken.  The 320 is one of my favorite modules.
And, I would like to echo the comments concerning using the 320 in the
audio range.  It bakes a much better sounding smooth sub-osc than the 120
square waves out.  Just use the 120 to sync it up, since the 1 v/oct scale
is close but not designed to be exact (per Paul).
Larry H
2000-03-21 by David Bivins
Don't forget using a self-oscillating 420 (and the forthcoming 440) as a
sub-oscillator. The 420 tracks very well (though I haven't tried it over a
wide range). The sine puts an unobtrusive bed in there; if you want to give
it more presence, send it through the 120.
David.
> From: J. Larry Hendry [mailto:jlarryh@...]
> Sent: Monday, March 20, 2000 5:24 PM
> Subject: Re: [motm] VCO concept...
> From: "J. Larry Hendry" <jlarryh@...>
> Larry H
> GET A NEXTCARD VISA, in 30 seconds!  Get rates as low as 2.9%
> Intro or 9.9% Fixed APR and no hidden fees.  Apply NOW!
> http://click.egroups.com/1/936/3/_/529958/_/953594272/
2000-03-21 by davevosh@aol.com
In a message dated 00-03-20 15:20:54 EST, you write:
<<  Is this technically feasable? >>
paul,
there has been a "symmetric ramp modulation" ( ie : sawtooth "pwm" type of
thing ) designed before, i`ve seen it in an "electronotes" vco design. maybe
paul could look at this for a revision of the motm vco module - ?
best,
dave v.
