900 power plans
2000-04-05 by thomas white
Hi Friends, The 900 power supply will power around 22 modules so you should be right around capacity with 20. Add up your milli-amps and see what your total will be. 800 is the max if I remember correctly. I plan to power 4 rows from one supply in my set-up and I don't anticipate any problems. I mounted my power supply on the rear rails of my SKB case and I will mount the distribution board for my 2nd SKB on the rear as well, mounted to a blank MOTM panel with one cord connecting the 2 cabinets for power. Should be a tight transportable system when I'm finished. Your module plan is very similar to mine, but I now think I am going to go towrads a polyphonic modular in the long run. Wish me luck and patience. Thanks for listening Thomas White (8 modules with 2 on the way!) MOTMMOOGERBLACET spaceship leaving in fifteen minutes for deep space launch... >So here's what I finally end up with: > >Qty Spcs Description >--- ---- ----------- >3 6 300 Ultra VCO >2 4 320 VC LFO >1 2 410 Triple resonate filter >2 4 420 VCF >1 2 700 VC Router >3 3 800 ADSR >2 4 940 Patch Panel >1 2 440 SSM VCF >1 2 110 RM/VCA > >I already have: >1 3 900 Pwr >1 2 100 Noise/SH >1 2 110 RM/VCA >1 2 120 Sub-Octave Mux > >I will also need: >3 Rack rails >1 Extra power distribution pcb > >I'll only have two VCAs and know I will need more, but I'll >wait for the new one. That's 38 spaces, four rows, with a >2U open. I guess I'll either save that for the next goody, >or use it for a breakout of an expressionist. That also >brings me up to 20 modules, so I guess I can use my motm >points to get two free modules. Brings me close to 2k, >which is what I planned to spend anyway. > >Good grief, I'm drooling... > >Thomas ______________________________________________________ Get Your Private, Free Email at http://www.hotmail.com
