more with less
2000-04-21 by David Bivins
Hey, After I sent the post about my 410-heavy track, I was thinking about another new track I have up, "Bug Oscillation." (http://www.mp3.com/baldbastard) I think it's pretty neat, but that's beside the point. I find that a lot of my tracks are really simple (I'm sure a lot of you do too ;) ) and they're even simpler in execution. So I've decided to tell the story of this track for those who like hearing about how others' modulars are used. Event 1: A near-mint KPR-77 (old Korg analog drum machine, somewhat similar to the Roland TR-606) showed up in the mail for me. It even had the original carrying bag. I used to have one of these, but it was really beat up (it used to belong to a popular, gigging techno musician). This new one is nearly perfect and is very easy to program (no key bounces like the old one). Event 2: I remember that the KPR runs at 48ppqn, unlike Roland's sync24 (24ppqn). Instead of reprogramming the 77, I let the 303 run at double-speed with a 16th (now 32nd) note pattern, one note with slight variation in rhythm at the end of the measure. Event 3: I send the 303 (via headphone output) into the modular. Routing's through a couple of 420s, modulated by a 320 LFO. The first 420 is in HP, the second LP. Both have resonance set to about 7, just where you can really start to hear the effect. The 303 is also going into the mixer independently via the "regular" output. Event 4: I trigger an EG via one of the KPR-77's trigger outputs. Like many drum machines, the triggers are from the toms, so you can hear the effect quite clearly in the track if you're listening for it. The EG modulates the VCA, out of which the 303 finally comes. So it's this quick-vibrato-type sound that hits simultaneously with the high tom. Event 5: I bring the 303 in on the mixer in its full pattern form. No one I've played this for realizes that it's the same thing that's coming out of the modular. So one note and one drum machine pattern were used in the creation. Some might say it's boring, but others might be kind and call it "minimal techno" or something. I really love using one sequence to spawn many distinctly different events. I'm hoping that the lag processor will really open things up for me in this respect. I'd also be interested in something that can delay a trigger... can an analog delay be used to delay voltage triggers? Or do I need something like a string of capacitors? David. http://www.mp3.com/baldbastard http://www.mp3.com/stations/baldbastard
