Re: [motm] Thank God!!!
2000-05-09 by Paul Schreiber
Sure it wasn't a bad '800? Check the wiring on the cable. I have seen 1 (out of ~1000) cables that had the 2 outside wires 'crossed'. I now try to check for this as I pack them up. Paul S. ----- Original Message -----
From: Nathan Alan Hunsicker <nate@...> To: MOTM Newsgroup <motm@egroups.com> Sent: Monday, May 08, 2000 7:03 PM Subject: [motm] Thank God!!! > I finished building my 410 today. After replacing that pesky TL074 op > amp I put in backwards, I was ready to power up the module and test it. > When I connected it to the power supply and turned it on, everything > stopped working, the light on my LFO was showing a dim green and was not > oscillating. Of course I immediately turned the PS off and disconnected > the 410, powered back up and everything works fine. Now I'm thinking > something is shorted out so I take one last look at EVERYTHING, not one > thing wrong (except for a resistor not facing the same way as the > others.) my next thought was does my PS have enough power to run all my > modules? I only have a 300, 320, 110, 120, 420, 410 & three 800's, it > couldn't possibly be the PS, but just in case, I disconnect one of the > 800's and try again, SUCCESS!!! So now I'm thinking I need another PS as > I prepare the module to put in my rack, I plug it back in, bolt it to > the rack rails, power up and WHAMMO, it happens again. I'm totally lost, > just as a last resort I try switching the MTA cable to the one that was > powering the 800 and it works! For some reason, when the bad MTA cable > is not connected to a module, it is fine, but as soon as I connect it to > a module (any module) it shorts out. I am so glad that it was the cable > and not my module. NOW, what was the reason I typed all of this you ask? > Just in case you build a module and can't figure out why it doesn't > work, don't forget the obvious, test the power cable. -Nate > > ------------------------------------------------------------------------ > You have a voice mail message waiting for you at iHello.com: > http://click.egroups.com/1/3555/5/_/529958/_/957831275/ > ------------------------------------------------------------------------ > >
