MOTM
RE: [motm] Troubleshooting a short
2000-05-09 by Paul Wagorn
hey david:
next time, just send it to me right away, I'll fix it for you...;)
-paul
(still mad that biv got the last router!)
Sent: May 9, 2000 11:37 AM
To: MOTM
Subject: [motm] Troubleshooting a short
Hi all,
I had some trouble with the 700 vc router I just built. Luckily, Paul was
available for some live tech support and I got it sorted out. Because the
problem seemed like it *could* conceivably happen more than once, I'd like
to tell you all about it.
The way the coax attaches to the jacks, the braid is pulled to one side
first and twisted. On a particular strand of coax, the inner insulation had
melted or been cut through (very fine break) and the braid was resting
across it, causing a short. I couldn't see this at first and went through a
lot of trouble disassembling the PCB sandwich, etc.
So if you're having trouble, don't forget to look at the easier solution
first. I had carefully scanned the PCB twice, including verifying component
placement, before I looked at the other end. And considering the iron
proximity we have to work with sometimes when wiring the front panel, it's
fairly easy to slip and melt a bit of insulation.
David.
http://www.mp3.com/baldbastard
http://www.mp3.com/stations/baldbastard
Get your money connected @ OnMoney.com - the first Web site that lets
you see and manage all of your finances all in one place.
http://click.egroups.com/1/3012/5/_/529958/_/957890820/
Re: [motm] Troubleshooting a short
2000-05-09 by velure
> And considering the iron proximity we have to work with sometimes when
wiring the >front panel, it's fairly easy to slip and melt a bit of
insulation.
that's why i jump to the end of the instuctions and wire up the front panel
jacks and knobs before i assemble the unit.  i guess after you build a few
panels, you'll figure out what works best for you.
-steve
2000-05-09 by Nathan Hunsicker
Does this mean that you are out of 700's right now? Which modules are
available and which are backordered? -Nate
>hey david:
>-paul
>-----Original Message-----
>From: David Bivins [mailto:dbivins@...]
>To: MOTM
>Hi all,
>David.
><http://www.mp3.com/baldbastard>http://www.mp3.com/baldbastard
><http://www.mp3.com/stations/baldbastard>http://www.mp3.com/stations/baldbastar
>d
><http://click.egroups.com/1/3012/5/_/529958/_/957890820/>http://click.egroups.c
does that mean that you're giving me my 303 back, david ? :)
on a different note, I want to make a really simple cabinet for 2 rows of
modules....
what is the deepest module that is out there right now?  i took a quick look
through
the archives & haven't found anything...
..or does someone have a flipup mixer skb case that they want to sell me to
mount my
motm in?
-paul
(who was getting seriously offtopic)
Sent: May 9, 2000 12:21 PM
To: motm@egroups.com
Subject: RE: [motm] Troubleshooting a short
Oh, cool!
I have this thing called a Computer Controlled TB-303. It makes a really
annoying, shrieky sound when I turn up the resonance and turn down the
cutoff, so it must be broken. If I sent that to you, Paul W., would you fix
it for me and hang on to it for awhile to make sure it works?
> From: Paul Wagorn [mailto:pwagorn@...]
> Sent: Tuesday, May 09, 2000 11:06 AM
> hey david:
> -paul
> To: MOTM
> Hi all,
> insulation had
> through a
> component
> David.
> You have a voice mail message waiting for you at iHello.com:
> http://click.egroups.com/1/3555/5/_/529958/_/957892128/
eGroups eLerts
It's Easy. It's Fun. Best of All, it's Free!
http://click.egroups.com/1/3863/5/_/529958/_/957892872/
2000-05-09 by Dave Bradley
> modules....
> quick look
> through
They are all the same depth, except the 800 which is shallower. Just measure
one of your modules.
Dave Bradley
Principal Software Engineer
Engineering Animation, Inc.
daveb@...
2000-05-09 by David Bivins
Hi all,
David.
2000-05-09 by hodad1@mindspring.com
I too have had this problem.  Checking for shorts on the jacks is a great
place to start when
troubleshooting a module.  And checking for solder bridges on switches.
That's my experience anyway.
tomr
To: MOTM <motm@egroups.com>
Sent: Tuesday, May 09, 2000 2:37 PM
> Hi all,
had
a
component
> David.
Oh, cool!
> hey david:
> -paul
> To: MOTM
> Hi all,
> insulation had
> through a
> component
> David.
True, true. That's not a bad idea, really--you can pin the wires down
between jacks while soldering, totally out of the way...
Thanks for the tip!
David.
> From: velure [mailto:velure@...]
> Sent: Tuesday, May 09, 2000 11:08 AM
> Subject: Re: [motm] Troubleshooting a short
> insulation.
> front panel
> -steve
> Buy and sell used, rare and vintage gear at the Web's best
> music gear auction. Register to enter the weekly gear giveaway!
> http://click.egroups.com/1/3730/5/_/529958/_/957892529/
