> From: Dave Bradley [mailto:daveb@...]
> Sent: Wednesday, May 17, 2000 1:41 PM
> To: motm@egroups.com
> Subject: RE: [motm] motm100 tech ?
> Are you listening to the S&H output as an audio device? That's not what it
> is meant for! It generates control voltages to modulate filter and
> oscillator tuning, etc. The output is a varying dc voltage, and will cause
> clicks or thumps if you try to listen to it directly. For the same reason,
> you can't listen to the output of an envelope generator.
> Dave Bradley
> Principal Software Engineer
> Engineering Animation, Inc.
> daveb@...
> > From: mark scetta [mailto:n0nspaz@...]
> > Sent: Wednesday, May 17, 2000 12:34 PM
> > Subject: [motm] motm100 tech ?
> > i still get a glitch sound every time my S&H outputs, in both track and
> > hold modes (much bigger glitch in track mode). try it: with
> > nothing plugged
> > into the MOTM-100, listen to the output in both modes.
> > i have tried putting a resistor in series with the output and small cap
> > across the output to ground, to no avail. how are you guys using
> > your S&H?
> > doesn't this bother anyone?
> > thanks ahead,
> > mark
> $60 in FREE Long Distance! Click Here to join beMANY! today.
> http://click.egroups.com/1/4126/5/_/529958/_/958585308/
